Removing Towel Rack From Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 06:20 PM   #1
Rewards Points: 150
Removing towel rack from tile
In my shower there are two ceramic towel rod holders stuck to the tile. For a bath this is fine, but if one wants to take a shower it gets in the way of elbows. I tried to remove the towel rack by heating it using a propane torch for sweating pipes but it did nothing.
Is there a way to get this off without destroying the tile underneath? Thanks in advance for all answers.
Cossack is offline   Reply With Quote
Old 01-14-2009, 07:36 PM   #2
Rewards Points: 22
Is there by any chance a really small set screw on the bottom of the holder that attach's to the wall? Every towel rack that i have seen has a very small set screw on the bottom of the rack right by the wall.
ponch37300 is offline   Reply With Quote
Old 01-14-2009, 08:18 PM   #3
Rewards Points: 150
I will double check, but I looked all over the towel rack holder as I applied the torch and I did not see any such thing. My house was built in 1863, so I don't know when this was installed.
Old 01-14-2009, 08:29 PM   #4
Rewards Points: 22
If you could post a couple of pictures that would help see what kind of towel rack you are dealing with.
Old 01-14-2009, 09:28 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
is the towel rack ceramic?? if so then the whole assembly sounds as tho it is set in mud. then the only way to remove it would be to grind it off with a diamond blade. then chipping the remainder of that tile out, then you will have to try and match the tile. more then likely the whole tile job was mud set.
BOB
P.S your saying 1863 or did you mean 1963?
Old 01-15-2009, 06:11 AM   #6
Man of many hats
wrangler's Avatar
Rewards Points: 354
I often have to remove these and just use a hammer to break the holders (BE SURE TO USE GLOVES AND PROTECTIVE EYEWEAR!) Be careful to not hit the adjacent tiles. After you have the majority of it broken off, use an old chisel to remove the remaining chunks that are set into the mud. Depending on the style these are often set using a half tile to fill a 'whole' tile space, or even centered on a grout line with a half tile to either side of it. These will have to be removed as well. Then you can replace with a complimentary color or a decorative tile as it will probably be impossibly to match your current tile.
Man of many hats
wrangler is offline   Reply With Quote
Old 01-17-2009, 08:40 AM   #7
Drywall contractor
Rewards Points: 1,070
Put something in/on the tub surface to protect it too when you go to knocking chunks of ceramic out....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
removing glass 4x4 tile tilewoes Building & Construction 1 06-10-2008 09:54 PM
Removing Ceramic Tile csnolan General DIY Discussions 1 10-26-2007 10:37 PM
removing a tile towel bar amyrdh Remodeling 1 05-22-2005 06:35 PM
