Removing Subfloor Seem To Have A Little Problem And Have Some Questions - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-20-2009, 01:21 PM   #1
K.M.G's Avatar
Rewards Points: 109
Removing Subfloor seem to have a little problem and have some questions
Hi
I took it upon myself to want to remove the old 5/8's OSB Sub-floor as it has major water damage and squeaks and has maybe 15 screws+Nails holding it together.
I have started out fine but my reciperating saw/Circular saw can only get so close to the stud wall(Sole Plate)
So It's been cut on a slight angel
Now I went and bought a new 2x8 to double up the other one so I can have a place to screw the new 5/8's plywood down along that wall as I would not have anywhere(schluter ditra says 5/8's will do fine) Spoke right to owner
2x8 Joists 16" OC
The Sub floor in the hallway is 5/8's too so I wanted everything the same height+Ditra will add some thickness and the 13x13 tiles to
Should I just leave the little bit of old 5/8's along this wall or is there another way beside getting a Toe Kick saw to remove it possibly a saw blade made for a reciperating saw.
When striping a old sub floor usually right to the joists do you ever get the 1"-2" under the Stud sole plate too.
I thought I would ask as I'm not really sure and don't know who else to ask on this subject.
Any help would be great
K.M.G is offline   Reply With Quote
Old 09-20-2009, 03:02 PM   #2
Drywall contractor
Rewards Points: 1,070
Not my area of expertise, but I would think the 2"x8" you add would be sufficient to control any "flex factor" that would cause the tile to crack. Lots of glue and screws/nails will ensure a good bond of the two framing members. If you're concerned, you might want to try one of the new "multi tools" on the market for flush/under cutting. They are very handy for a variety of uses. The Dremel runs about $100.00 at HD or Lowes.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-20-2009, 09:55 PM   #3
K.M.G's Avatar
Rewards Points: 109
That Does not should like a bad idea at all thanks a lot
I could cut the OSB straight to the wall or as close
I saw that tool at the wood working show and didn't think anything of it but as what is that noise over there.
Old 09-21-2009, 08:35 AM   #4
Drywall contractor
If you get one you'll wonder how you ever got along without it.
