Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-20-2011, 09:22 AM   #1
removing a stair case
Hey diy nation. New to home improvment so please bear with me. My wife and I will soon be inheriting a house from my inlaws and there is a pretty big change I would like to make to it. The house has two stair cases in it (it used to be a duplex) and I would like to remove the one in the middle of the house and put up a wall using four posts. This way I can turn that space into a master bedroom closet upstairs. Just wondering if this was even possible as long as I have it properly supported with the posts.
Superbeef83 is offline   Reply With Quote
Old 07-20-2011, 09:37 AM   #2
Experienced
Jackofall1's Avatar
Welcome Superbeef83, to the best darn DIY'r site on the web.
You should post some pic's of the stair to be removed to help understand the existing structure. Many times the stair opening is framed in a way to support the stairs and there may be a possibility that you will not have to add any support posts, but without a visual there is no way of making any additional comments.
If you think you need to add posts a structural designer or engineer would be a wise choice to ensure that the integrity of the area is not comprimised.
Mark
Old 07-21-2011, 03:48 PM   #3
These are the stairs in question. The last picture with the small curtain on the bottom is a shot of the bottom of the stair case. If I could remove them completely and not have to add any support that would open the downstairs up a bunch.
removing a stair case-forumrunner_20110721_144454.jpg   removing a stair case-forumrunner_20110721_144515.jpg   removing a stair case-forumrunner_20110721_144537.jpg   removing a stair case-forumrunner_20110721_144558.jpg
Old 07-21-2011, 04:35 PM   #4
Framing Contractor
The stairs themselves are not holding anything up. The walls next to the stairs could be. Reframing these walls is pretty easy to do if it is necessary at all. You will have to do some investigating to figure out the best way to go. You need to determine if the second floor floor joists are being supported by these walls.
sixeightten is offline   Reply With Quote
Removing Stubborn Tub Spout 347Cougar Plumbing 6 12-27-2012 04:12 PM
stair case relocation Menna Woodworking 0 07-11-2011 04:28 PM
Stair Nose Attachment - HELP! BSponz1 Flooring 3 01-10-2011 02:31 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
