Removing Smoke & Soot From Brick Fire Place - Extensive Fire Damage In House - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 03:27 PM   #1
removing smoke & soot from brick fire place - extensive fire damage in house
How do you remove soot from brick on exterior of brick on fireplace in living room? Our house has had much fire damage on the inside. We are tearing out all the sheetrock, cabinets, et.
Hargrove is offline   Reply With Quote
Old 06-09-2011, 03:29 PM   #2
Old 06-09-2011, 04:37 PM   #3
DIY staff
Rewards Points: 7,174
Soda blasting will return that to like new.
Contractor Talk - Professional Construction and Remodeling Forum
Go to the sand blasting section and look around---The site is for pros only so you may look but not join.--Mike---
Fire ants coming into house through pipes in foundation -- need advice samalex Pest Control 15 03-22-2011 01:35 PM
Old brick addition on old brick house, pulling away? Salvatorparadise Building & Construction 7 11-23-2010 06:05 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Laminate Flooring around a brick fire place pamedic13 Flooring 6 11-21-2006 08:42 PM
