Removing Screen Porch Posts For Eze-breeze - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 01:05 PM   #1
Removing screen porch posts for eze-breeze
I'm thinking to install eze-breeze windows in my screen porch.
Eze-breeze info: http://www.pgtindustries.com/Pages/Main.aspx?PageID=105
I'd like to remove some posts so I can have fewer and larger windows, see picture:
I'd like to do the same all around, reducing the number of posts by about 40%.
Does it look like this will be OK?
Thanks,
D2.
Dutch2 is offline   Reply With Quote
Old 02-12-2011, 03:21 PM   #2
Rewards Points: 5,336
You would need to know how the structure was built to know if you could remove any structural elements.
Were plans filed for this ?
Ron
Old 02-12-2011, 05:07 PM   #3
In other words it is not as simple as the posts on the corners plus the headers hold it up and the rest is just there for the screens?
It was originally built with the house so there were plans... I'll have to look what I have.
D2.
Old 02-12-2011, 11:16 PM   #4
D2.
It could be that simple. The wall with the door has 6 posts for a wall about 11 or 12 feet?
What about the rest of the structure? The opposite wall is the same? What about the connecting wall? How long? How many posts?
You can't show one wall, say you want to remove 40% of the posts and expect any sort of useful guidance.
What sort of snow load do you get?
Ron
Old 02-20-2011, 05:09 PM   #5
OK, point taken, more information needed
Here is a picture of the "long" side:
The screen room is 15 feet wide by 12 feet.
On the 15 feet side I want to remove the 4 existing 4x4 wooden posts and replace them with 3 2x2 aluminum posts. I want to use 2x2 because the windows are 2" deep and will mount flush with the 2x2.
On the 12 feet side with the door I want to remove the 4 existing 4x4 wooden posts and replace them with 2 2x2 aluminum posts.
On the other 12 feet side I want to remove the 3 existing 4x4 wooden posts and replace them with 2 2x2 aluminum posts.
The 4 corners will remain 4x4 wooden posts.
The other 15 feet side is attached to the house.
Snow load... I have no idea. I'm in Charlotte, North Carolina and we don't get a lot of snow.
Hope this makes sense, thanks for your help.
D2.
Old 02-20-2011, 11:05 PM   #6
What is the weight capacity of the aluminum poles? Will it hold the structure?
I'd contact a structural engineer to do a load analysis and get his recommendations.
You can't guess at this.
Ron
Old 03-23-2012, 09:41 AM   #7
eze breeze oists
Dutch:
What did you end up doing with your porch. We are interested in doing something similar. removing posts etc.
J Douglas is offline   Reply With Quote
Steel Posts for Screen Porch dobbsj Building & Construction 2 07-15-2009 06:47 PM
Saddle for screen porch gorf Roofing/Siding 1 06-19-2009 05:33 PM
Screen porch ceiling archbarb General DIY Discussions 1 01-24-2009 10:15 AM
Need some DIY Screen Porch Help dws1216 Building & Construction 5 06-22-2008 09:19 AM
Removing sliding screen door Keyo77 General DIY Discussions 4 08-18-2007 08:13 PM
