Removing Purlins - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 07:20 PM   #1
Removing purlins
Hi there. I'm in the process of remodeling a section of my attic into a bedroom. Or rather I'm in the final stages of the planning. Everything should be all set, however the purlins (I believe that's what they're called; the horizontal members going from one rafter to another on the opposite side of a gable roof) are in the way. They are 6 ft up from the joists. I'd like to relocate them about another foot up for headroom, for a total of 7 ft (I'd also be replacing them with 2 x 6s, because currently they are 2 x 4s). I am aware that this may be a problem (roof sagging). However I am also placing knee walls (should be about 4 ft high) at 5 ft from the eave on both sides. Would this be enough to provide sufficient support for the roof, altogether? The span across is 25 ft. Also, I plan to sheetrock the entire area (knee wall to rafter to purlin, across the purlin, down the rafter to the knee wall). Would hanging the sheetrock from the purlins cause any issues? I'm aware of how what needs to be done (insulation-wise and whatnot) otherwise. Attached is a picture. Thanks.
GottaDIY is offline   Reply With Quote
Old 06-02-2011, 07:23 PM   #2
Framing Contractor
Rewards Points: 118
My gosh, those rafters are only 2x4??
Those things you refer to are called collar ties. Yes they do help the roof. Putting them up too high reduces their effectiveness.
sixeightten is offline   Reply With Quote
Old 06-02-2011, 07:28 PM   #3
Ah, okay thanks. The collar ties are 2 x 4 (1-1/2" x 3-1/2") however the rafters themselves are something else (1-1/2" x 4-1/2"), it's weird. Would the knee wall help support, though?
Old 06-02-2011, 07:31 PM   #4
Framing Contractor
Rewards Points: 118
Technically, the knee wall will not offer true support because they themselves are supported only by the joists below. You could probably check with a string to see how much droop the ridge currently has. If it is pretty straight, I wouldn't hesitate to move those up maybe 6 inches, and upgrade them to 2x6.
Old 06-02-2011, 07:37 PM   #5
Okay, thanks again. One more thing, though. Would hanging sheetrock from the collar ties be an issue?
Old 06-02-2011, 07:42 PM   #6
Framing Contractor
Rewards Points: 118
Not as long as they are adequately sized. For a 2x6 16" on center, I think you can span at least 11' on a ceiling joist. Make sure everything is properly ventilated and insulated prior to the sheetrock. If you will be adding any electrical, obviously that needs to be in as well.
Old 06-02-2011, 07:50 PM   #7
Okay, good. The span would only be roughly 6 or 7 ft if I raised the collar ties up a few inches. The pitch is pretty steep, so down below at the eaves it's 25 ft. But up at 6 ft, it's only barely 10 ft. Thanks, again.
Old 06-02-2011, 07:50 PM   #8
kwikfishron's Avatar
Rewards Points: 418
Hope you don’t break your ceiling you’re now turning into a floor. How much weight do you think it will hold?
kwikfishron is online now   Reply With Quote
Old 06-02-2011, 08:03 PM   #9
That I'm not too worried about... I spent a whole day clearing out all kinds of crap from that section of the attic. A lot of "dead" weight (I know it's not actually dead weight, but for the amount of time most of that stuff's been up there, it might as well be considered as such) was up there. I don't think I'll be adding much by placing an open room in all of the stuff's place. The only things up there will be a queen sized bed, a small desk and computer, a dresser (there were two heavy ones up there before cleaning), a person, and a small table maybe? Though it did cross my mind.
Old 06-02-2011, 08:09 PM   #10
Framing Contractor
Rewards Points: 118
I recently worked on a similar attic. Existing joists were 2x4 on 24 inch centers spanning over 11'. Shot a laser across and saw that from highest to lowest there was a 3" diff. We ended up building another floor above the existing using 2x6 on 12" centers. Ceiling height changed from 8' to 7'4, but all in all it was the best way to go.
Old 06-02-2011, 08:22 PM   #11
Rewards Points: 418
How about the sheetrock? Where’s all the weight of that load going to transfer to?
Old 06-02-2011, 08:35 PM   #12
True story... Actually, thinking about it, some of the sheetrock will be supported by the existing, load-bearing, exterior walls; some by the rafters (which would be transferred to the exterior walls below); and the rest by, of course, the floor (being attached to the 4 ft high knee walls on the perimeter). It would only be the approximately 32 lineal feet in all, and only half a sheet high.
Old 06-02-2011, 08:40 PM   #13
Framing Contractor
Rewards Points: 118
The floor loading is a valid point. If the floor sags, so does the rest of your work, and the ceiling below. Do some checking, and see what can be done to improve the performance of the floor. I agree that the loading of the drywall is minimal. The loading of furniture and people, a bigger concern.
Old 06-02-2011, 08:42 PM   #14
The existing joists are 2" x 6" and 16" OC with cross-bridging. I'm not sure of what else I could do... any suggestions?
Old 06-02-2011, 08:45 PM   #15
Framing Contractor
Rewards Points: 118
The span of the joists is what is important. You may be able to double up every third joist, but sometimes electric, plumbing, hvac makes this tough.
You should also check the existing floor with a string and see how much deflection is there already. This will probably be a real eye opener for you.
Removing window and patching stucco mark_anderson_u Remodeling 4 12-27-2010 11:04 AM
Please help with removing caulk/paint-prep RinSF Painting 2 12-26-2010 07:06 AM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
standing seam over purlins hawaiidiy Roofing/Siding 5 11-21-2009 07:00 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
