Removing A Pre-fab Fireplace Insert - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 12:34 PM   #1
Removing a pre-fab fireplace insert
My house was built in 1991. It has a pre-fab fireplace insert that developed a leak, it has damaged the exterior and the interior ceiling.
After long family deliberations we've decided to remove the fireplace. The exterior shell of the fireplace is 16ft high, making it extremely difficult for me to work on.
My questions are:
1. How hard is it going to be for me to tear the existing fireplace stack down?
2. What will I be up against in removing the actual insert?
All comments are appreciated.
MarkinTN1 is offline   Reply With Quote
Old 10-10-2009, 12:20 AM   #2
Registered User
Rewards Points: 4,912
Start at the top with the actual pipe, comes in 3'sections. 1/8 twist lock/unlock turn, or sheet-metal screws at joints. Pull perimeter nails at cap, remove.Remove siding, corners, ply or OSB. Remove framing above roof, patch roof. Remove brick veneer, drywall and inside framing. Then inside pipe down to stove. Unit is heavy, 300#, use a hand truck or young bucks. Remove outside siding, corners, framing OR just leave the lower half as it is on it's own concrete foundation wall and footing, a mess to lower for the new slab (which won't match). Extend the rafters over the top and add new comp. shingles. Gutter there will be a problem......
Be safe, Gary
Fireplace insert flue closure air-tightness fishmanflats HVAC 7 12-21-2008 07:19 PM
Fireplace Insert mcblackburn@nc.rr.com General DIY Discussions 6 11-19-2008 10:33 AM
Ventilation for fireplace insert dpreznik HVAC 3 07-28-2008 07:59 PM
Gas Insert is too small for fireplace! manOfConstantSorrow HVAC 1 02-23-2006 07:07 PM
