Removing Plaster And Installing Sheetrock - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 09:47 PM   #1
Rewards Points: 229
Lightbulb
Removing plaster and installing sheetrock
I am in the process of brainstorming remodel plans.
Here's the situation : This house I will work on has old wiring, few outlets, and paneling over lath and plaster walls (an assumption). The paneling is likely put up with nails, not certain yet. I want to paint walls certain colors, and paneling is going to prevent that as far as I know. I also need to install new / more outlets so I don't know about leaving it up for that purpose either.
I would like to put some outlets in exterior walls, and I think they have a form of insulation possibly blown in. Would it be okay to leave the lath up to hold it in and put drywall over the lath with a bit longer screws?
AlphaPilot is offline   Reply With Quote
Old 09-17-2012, 08:57 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
I am in the middle of doing my front room right now. I found that the blown in cellulose had settled almost a foot at the top and was absent from many places altogether. So I quickly decided to strip it down to studs so I could install fiberglass. Another thing to consider with leaving the lath in place is future anchor placement. The lath will make this very frustrating.
PoleCat is offline   Reply With Quote
Old 09-17-2012, 02:01 PM   #3
Rewards Points: 229
If the insulation is compacted, it's most wise to rip it out, correct? If so - any favorite method to do so?
Old 09-18-2012, 07:25 PM   #4
PoleCat's Avatar
I removed the lath. verything is easy from there.
Old 09-27-2012, 07:54 PM   #5
Rewards Points: 16
One way would be to rip out the lath, more work and mess, I know. But it would be nice to have it down to the studs to run new wiring.
Do you know if you have proper studs behind the lath? You need to find out.
Trying to sheetrock over a wobbly lath wall is going to be a nightmare if you want it to look decent.
Once you have it all exposed and the wiring is run, you can insulate properly and easily now.
This might be the better way and worth it in the long run.
Good luck.
chongololo is offline   Reply With Quote
Old 09-28-2012, 08:15 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
chongo is correct. old homes have studs that vary greatly from one to the next its why the plaster in them goes on so thick. its to even out the walls to create a flat surface
woodworkbykirk is offline   Reply With Quote
WAINSCOTTING With BEAD BOARD Nathan Carpentry 29 02-24-2013 04:42 PM
Mating drywall to plaster on an inside corner acme54321 Drywall & Plaster 4 10-14-2010 12:09 AM
Plaster Walls? I dont know? chsitko Drywall & Plaster 4 08-28-2010 06:30 PM
Installing baseboards on lath & plaster B Scott Remodeling 6 07-05-2008 10:29 PM
Installing Crown Molding in Plaster hoboing Carpentry 8 05-25-2008 08:11 AM
