Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 12-11-2012, 08:26 PM   #1
removing part of a wall
I have a kitchen wall that I would like to remove from the counter up to the ceiling. Pulled drywall and it extends out the back of the house forming the exterior wall of breakfast nook. It is supporting the beam running across the top of the nook. If I put about 4 2x4 in that corner creating a point support I should be fine removing the rest of hat wall. Anybody have any experience doing anything like this.
timmsjc is offline   Reply With Quote
Old 12-11-2012, 08:29 PM   #2
Got at least a picture?
Old 12-11-2012, 08:33 PM   #3
DIY Enthusiast
sublime2's Avatar
If you are pulling a wall that is supporting a beam that inturn supports the 2nd floor or roof.
You need to support the beam across its length with temporary framing infront of the wall your removing.
Its a load bearing wall you need to support the load the wall your removing is now supporting.
sublime2 is offline   Reply With Quote
Old 12-11-2012, 08:40 PM   #4
I'm not removing the section of the wall that holds up the beam. The rest of he wall is parallel to the floor joists with none of them resting on it. Plan is to add a couple extra 2x4s under where the beam sits on the wall. I'm working on getting a picture up.
Old 12-11-2012, 08:52 PM   #5
This is the corner. Beam in ceiling running perpendicular to yellow wall. This corner is staying and is where I will add support behind what is there already.
Replacing part of exterior wall Wayne Perry Building & Construction 3 11-19-2012 12:50 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Removing wall in home Chasm Building & Construction 15 12-15-2009 08:33 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 06:10 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
