Removing Painted Popcorn Texture From Ceiling - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-07-2006, 10:04 PM   #1
Removing painted popcorn texture from ceiling
i have removed popcorn texture from ceilings with water and putty knifes and it isnt that bad, but im going to be removing one that has been sprayed with paint, i dont think the water will penetrate that well, so is there a way i can do it with some other type of chemical? paint stripper? i dont know, any tips would help. thanks.
cnielsen4130 is offline   Reply With Quote
Old 10-10-2006, 06:49 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Should come off the same. Why do I say that?
Because, it is most likely a latex paint. As you probably know, latex is water soluble. So you should have no problem using the method you tried previously....
Good Luck
- Build Well -
Old 10-07-2007, 01:01 PM   #3
Popcorn Ceiling w/heating unit?
Hi,
We are wanting to remove the popcorn ceiling from our living room and feel confident that we can do it sucessfully but I still have a few questions.
Our home originally had ceiling heat, about 5 years ago we had forced air put in and the ceiling heat was disconnected. Will any of the wiring or heating unit be visable under the popcorn? Or does that sit on the attic side of the sheetrock?
Thank you
Laurie
loraljinks is offline   Reply With Quote
Old 10-07-2007, 01:21 PM   #4
Originally Posted by loraljinks View Post
Hi,
Thank you
Laurie
That's a new one. I can't help you there. Hopefully someone else may be more familiar with it.
- Build Well -
Old 10-07-2007, 03:30 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
All wiring should be on the attic side of the sheetrock. Popcorn wouldn't hide wire. Any unused old heating supply or return vent holes can be sheetrocked over.
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-07-2007, 05:39 PM   #6
popcorn ceiling
Hi,
We removed a small area of the popcorn just to see how difficult it was, so far it is very easy but we have an additional question.
My hubby is freaking out because the ceiling appears to be a light tan color not stark white. I think it looks like the mudding compound.
Do we need to just scrape the popcorn stuff, or does the tan stuff need to come off also?
We plan on just putting a bit of texture on the ceiling and then smoothing it a bit so it is more similar to the rest of the home.
Laurie
Old 10-07-2007, 06:30 PM   #7
The tan maybe the discolored paper surface of the installed sheetrock.
Just scrape the popcorn off. Re coat as needed. Prime and paint.
- Build Well -
Old 10-07-2007, 09:41 PM   #8
Mod / ArchiBuilder
Cole's Avatar
Ceiling Heat?
That is a new one for me, but I live in hot and humid Dallas, TX.
Cole is offline   Reply With Quote
Old 10-07-2007, 11:21 PM   #9
Exactly correct. I've scraped quite a few ceilings and it's always brownish. Just ,ake sure to scrape all the popcorn residue off.
send_it_all is offline   Reply With Quote
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
Retexturing painted popcorn ceiling kwehnes Building & Construction 6 01-02-2007 04:36 AM
Question about popcorn ceiling J187 Building & Construction 4 06-30-2006 01:33 PM
Removing popcorn from ceiling? Doug Crf Painting 5 05-22-2006 08:23 AM
