-   -   Removing painted popcorn texture from ceiling (http://www.diychatroom.com/f15/removing-painted-popcorn-texture-ceiling-4248/)
cnielsen4130 10-07-2006 11:04 PM
i have removed popcorn texture from ceilings with water and putty knifes and it isnt that bad, but im going to be removing one that has been sprayed with paint, i dont think the water will penetrate that well, so is there a way i can do it with some other type of chemical? paint stripper? i dont know, any tips would help. thanks.
AtlanticWBConst. 10-10-2006 07:49 AM
Should come off the same. Why do I say that?
Because, it is most likely a latex paint. As you probably know, latex is water soluble. So you should have no problem using the method you tried previously....
Good Luck
loraljinks 10-07-2007 02:01 PM
Popcorn Ceiling w/heating unit?
Hi,
We are wanting to remove the popcorn ceiling from our living room and feel confident that we can do it sucessfully but I still have a few questions.
Our home originally had ceiling heat, about 5 years ago we had forced air put in and the ceiling heat was disconnected. Will any of the wiring or heating unit be visable under the popcorn? Or does that sit on the attic side of the sheetrock?
Thank you
Laurie
AtlanticWBConst. 10-07-2007 02:21 PM
Originally Posted by loraljinks (Post 66755)
Hi,
Thank you
Laurie
That's a new one. I can't help you there. Hopefully someone else may be more familiar with it.
Mike Swearingen 10-07-2007 04:30 PM
All wiring should be on the attic side of the sheetrock. Popcorn wouldn't hide wire. Any unused old heating supply or return vent holes can be sheetrocked over.
Mike
loraljinks 10-07-2007 06:39 PM
popcorn ceiling
Hi,
We removed a small area of the popcorn just to see how difficult it was, so far it is very easy but we have an additional question.
My hubby is freaking out because the ceiling appears to be a light tan color not stark white. I think it looks like the mudding compound.
Do we need to just scrape the popcorn stuff, or does the tan stuff need to come off also?
We plan on just putting a bit of texture on the ceiling and then smoothing it a bit so it is more similar to the rest of the home.
Laurie
AtlanticWBConst. 10-07-2007 07:30 PM
The tan maybe the discolored paper surface of the installed sheetrock.
Just scrape the popcorn off. Re coat as needed. Prime and paint.
Cole 10-07-2007 10:41 PM
Ceiling Heat?
That is a new one for me, but I live in hot and humid Dallas, TX.
send_it_all 10-08-2007 12:21 AM
Exactly correct. I've scraped quite a few ceilings and it's always brownish. Just ,ake sure to scrape all the popcorn residue off.
