Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-17-2009, 05:39 PM   #1
Removing old caulk from fiberglass shower
I have to replace the sliding glass doors etc on my tub. It is a full size fiberglass, single peice unit. The unit, existing doors, and caulk are 20+ years old. Before starting, I'm trying to identify any "land mines" that may make the project difficult. One possible issue is removing the old caulk without damaging/marring the fiberglass tub and walls. Does anybody have any helpful tips/info on this?
Are there any other thorny issues I may run into?
Thanks.
not-real-handy is offline   Reply With Quote
Old 09-18-2009, 05:31 PM   #2
Well, those plastic razor blades work great for me when I want to remove old caulk. They scrape about as efficiently as their metal counterparts, but are not hard enough to damage fiberglass and acrylic. I've even used them to safely remove tar and sap from my cars without damaging the paint.
I tried some of the caulk remover years ago on a fiberglass shower stall. I thought it was slow, messy, and kind of sucked compared to just scraping it with a plastic razor. Maybe I was using a crumby version, though.
KAdams4458 is offline   Reply With Quote
Old 09-19-2009, 08:44 AM   #3
Thanks! I didn't know there were such things as plastic razor blades.
Another question: Is there some kind of treatment (like Armor-All) for fiberglass tubs/showers? Since I'm going remove the doors and tracks, I thought I'd treat the fiberglass if there is some product out there.
Old 09-20-2009, 05:41 AM   #4
Treatment for fiberglass showers and tubs... I've heard of some waxes, but have never used them. I hear they can help with water spotting.
Sometimes if a fiberglass or acrylic tub is looking a little dull you can polish it up with the same stuff you polish the paint on your cars with. (Learned that trick years ago on a fiberglass tub that someone scuffed up by cleaning it with a Scotchbrite pad.) Lots of elbow grease and polish can make them really shine.
You can polish everything with products that are "paint shop safe", and not have a problem with caulk sticking. Obviously caulk won't stick to a waxed surface, so save wax, if you choose to use it, for after everything is caulked, and don't ever put anything like wax on the floor - slick is bad in the shower.
I'd take a look around the Internet and see what people say about polishing (not waxing, but truly polishing) fiberglass. I bet you can find some good product recommendations on the auto/boat/detailing forums. A fiberglass shower isn't all that much different from a boat hull, so there's a good place to start.
Old 09-21-2009, 09:04 PM   #5
go Monarchs!
There are some good restoration polymers on the market that work well on fiberglass. Vivilon comes to mind, it shines fiberglass right up. Do a search for it online.
cheers,
Erick
ErickMcG is offline   Reply With Quote
Removing an old shower pan kvn Kitchen & Bath Remodeling 3 10-24-2010 09:23 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Backerboard under Fiberglass Shower Pan? BillyDIY Plumbing 2 12-17-2008 02:47 PM
Shower door install in unplumb fiberglass surround screenporch21 Building & Construction 1 11-24-2008 03:36 PM
