Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-01-2010, 06:03 PM   #1
removing load-bearing walls and moving the kitchen
We just bought a 22 y.o. home with a fabulous view, and we want to remove the two walls that divide the kitchen from the dining room and from the family room to capture the 180 degree view from any point on the first floor. WE are pretty sure that both walls are load bearing (unfortunately!). We want to completely remove the 14-ft wall between the living room and the kitchen. On the wall between the kitchen and the family room, we just want to open the top half of the wall to enable a kitchen sink/island combo by extending the existing wetbar
Question 1: What is the cost of removing these two walls? The house is a two-story with a day light basement. The walls to be removed are on the first floor. I figure we have to use professionals for this work because it involves structural changes.
Question 2: The existing kitchen is quite dimensionally challenged (14' x 5'). I am thinking of merging it into the existing living room, and moving the kitchen to the existing family room. The family room has a gas fireplace and a wetbar.
2(a) Would it be cost effective to convert the gas fireplace to an oven range with cooktop (as the gas line is already there) and the wetbar to a kitchen sink (as the plumbing is already there)?
2((b): Is there any part of the kitchen remodeling that we could do ourselves to save money?
We may have paid the house at least 25K over its market value because we were initially so blinded by the view that we overlooked the dysfunctional and outdated kitchen. So we would like to save in renovation to recoup some of the money loss by that boneheaded mistake. However, we want to do it safely.
Thank you so much for your help.
WannaReno is offline   Reply With Quote
Old 04-01-2010, 06:11 PM   #2
Xtreme DIY'r
Costs depends upon the beam, support needed, which will need to be sized & how much you DIY
Plus any electric plumbing etc that may need to be moved
Old 04-02-2010, 06:05 PM   #3
Drywall contractor
The place to start is with a structural engineer to determine how to go about doing what you propose. With enough money, almost any remodel can be accomplished. Whether it is feasible AND cost effective depends on HOW it can be done and still be code compliant. It will be a few hundred dollars well spent....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Tags
fireplaces, kitchen remodel, load bearing wall
Solve this!? Walls moving new construction bergerdude Building & Construction 15 02-01-2010 06:46 PM
Moving studs on load bearing wall for HVAC? grouse Building & Construction 1 08-20-2009 03:16 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Load bearing or not (diagrams and images!)? amclint Remodeling 9 11-17-2008 02:27 PM
moving another load bearing nailfun Carpentry 2 02-20-2007 09:10 AM
