Removing A Load Bearing Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2012, 03:24 PM   #1
Removing a load bearing wall
I have a load bearing wall that separates my kitchen and living room that i want to replace with a beam. The kitchen has another room on top of it but my living room is open. The wall is 15 foot tall with the second floor resting on it. There are 2 36 in doors in the wall and the wall between is 7ft. The total open span will be 13'6". The floor is built out of 2X8x10 and the wall that rests on it is 7foot tall and 12 foot in length. I want to use 2-2x12x14 yellow pine with 1/2 in plywood between them. I plan on supporting the outside of the beam with a 6x6 wood column on each end. Will this be significant to support the weight? The rafters do not rest on the wall.
Craig18 is offline   Reply With Quote
Old 11-30-2012, 05:06 PM   #2
Solutions (handyman)
Rewards Points: 364
You're asking an engineering question. I would contact your local construction union and ask the questions. My concern would be the weight factor and what you would do to support the upper area during renovations. Be careful on this one because you don't want anything to collapse. You will probably get some good responses, but keep safety for you and your structure first in mind. Good luck.
Mark Harvey is offline   Reply With Quote
Old 11-30-2012, 05:41 PM   #3
Too Short? Cut it Again!
You are changing structure so will no doubt need a permit. To get the permit your are probably going to need a drawing and structural engineer, building designer or architect sign-off anyhow so ask them what you need to support the new structure.
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Load Bearing wall or not? Dennis6950 Remodeling 5 02-01-2011 08:34 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
removing load bearing wall from first floor simvt1 Building & Construction 5 05-22-2009 09:15 AM
Removing load bearing wall jjbarnes911 Remodeling 6 01-08-2009 09:32 PM
