-   -   Removing Laminate Backsplash and Replacing Cabinets (http://www.diychatroom.com/f15/removing-laminate-backsplash-replacing-cabinets-144081/)
ayclobes 05-17-2012 01:17 PM
My husband and I want to remove the laminate backsplash in my kitchen and replace the countertops. We also want to update/replace the cabinets along with replacing the light fixture. We're not sure how to go about doing this, or what tools we need to do this also.
https://fbcdn-sphotos-a.akamaihd.net..._7603525_n.jpg
oh'mike 05-17-2012 09:04 PM
If you are replacing the cabinets--counter tops and back splash---
This is the order of things---
Order your new cabinets and wait till the cabinets are on hand before you demolish any thing..
Unhook the sink and remove the appliances--
Remove the counter top--usually screwed from inside the cabinets--
Remove the cabinets--cabinets are screwed together through the face frames,near the hinges--
Boxes are screwed to the wall---
When the wall is free of the cabinets---remove the drywall that was the old back splash area--a 4 foot strip is usually easiest--
Now you are ready to upgrade the electrical wiring--lower the drain for the sink (yes--lower it) sinks are deeper than ever before--and under mounted--
add wiring for cabinet lights---
add insulation where needed
replace the drywall and tape it (only finish tape the parts that show)
Install the new cabinets---call the counter top people--
Hook up sink and appliances.
