Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 07-15-2009, 03:18 PM   #1
Removing a kitchen cabinet, I give up...
I want to install a dishwasher in our new kitchen. I identified the right spot, next to the sink, with the right size... I just had to remove the cabinet and that seemed like an easy task.
The cabinet is not glued to the countertop, but despite removing all visible screws the cabinet does not come out, it does not even move a bit. Could it be glued to the floor?
Any suggestions?
If we finally give up and hire someone to do it, do you have any idea of how much would they charge for just removing one cabinet? (we are in New York, NY)
Thanks a lot!
CC
cold-fish is offline   Reply With Quote
Old 07-15-2009, 09:16 PM   #2
Household Handyman
At this point it seems like you have to make a decision you should have made before you started-do I have custom built cabinets or off-shelf cabinets? If they were custom built then you are in for some work for a DIY person. If they are off-shelf, as you would buy at your local builder supply store, then you should be able to remove just that one section. IMO-usually custom built will not have walls between sections, and off-shelf cabinets will. There's always the possibility that someone, when installing the cabinets, glued the off-shelf units together at the sides, making this difficult. Sit back, relax, think, think again, and re-approach the job. You'll figure this one out. Good Luck, David
Old 07-16-2009, 07:28 AM   #3
Cabinets are usually screwed to the wall studs high up, just below the CT. and to each other thru the stiles, often behind a hinge, or a drawer opening. And they may be screwed to the CT at the corner braces. Occasionally, also screwed to the floor, but generally only if it is an end cabinet.
Old 07-19-2009, 12:09 PM   #4
Try looking at the cabinets on each side of the one you want to remove. There could be screws going into the cabinet from either side. there could also be screws hidden under the hinges that hold the face frames tight.
On occassions, the countertop is glued to the cabinet top. Look for squeeze out at the contact points.
Ron
Old 07-19-2009, 08:15 PM   #5
Moderator
Pull the finish trim off the cabinet/floor joint. As said, may be screws there, one on each side, in front. Inside on the back horizontal rail at cabinet top, screws or nails, as said. On doors next to each other, is there a joint, or not? Be safe, G
help! bring my kitchen together NewlywedKristin Interior Decorating 10 10-26-2011 02:08 PM
kitchen under cabinet lights DIYGST Electrical 1 01-05-2009 02:01 PM
Kitchen Cabinet Broken Crackers Carpentry 4 03-27-2008 10:40 PM
Install a dishwasher in an existing kitchen cabinet shapeshifter Remodeling 9 03-16-2008 02:05 PM
average cost for kitchen cabinet refinish sil Painting 4 11-05-2007 11:24 PM
