Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-19-2011, 10:23 AM   #1
removing grout/tile sealer from solid granite
I have just had a tile backsplash installed in my kitchen. The installers must have gotten the sealer they used for the grout and tile on the new solid granite countertops. What is the best way to remove this film? Will the products listed on the sealer for cleaning any brushes or rollers safe to use on the granite? It is a sealer from Sparks called Stone Glamor. It is more of a film than pooled areas so scrapping will not work.
thanks,
GLS0628
GLS0628 is offline   Reply With Quote
Old 09-19-2011, 12:48 PM   #2
Tileguy
Bud Cline's Avatar
Seal the rest of the granite using the same sealer.
Old 09-20-2011, 12:56 AM   #3
Too Old
Are you sure it's a sealer maybe it's the grout film? Did you pay extra to have the grout and tile sealed? If you paid extra then have them correct the problem. If it's the grout film it will wipe off or have them come back.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 09-20-2011, 08:33 AM   #4
Military Mom of 4
Snav's Avatar
In the past I've had to buff it off with my husband's car-buffer.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Removing and saving granite counter tops LeviDIY Kitchen & Bath Remodeling 11 11-30-2010 05:28 PM
removing granite backsplash momof2labs Building & Construction 2 03-14-2010 06:10 PM
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 04:28 PM
Removing solid shower base with marble chips WoozyChain Plumbing 2 08-15-2009 08:10 AM
Removing a solid wood pre-hung door...... fastback4 Building & Construction 4 05-21-2008 02:15 PM
