Removing Fake Stone - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 12:06 PM   #1
Removing Fake Stone
Whats the best way to remove the old fake stone the is covering my entire chimney breast in the living room? Once removed is it just a case of adding new drywall to the breast and a lick of paint? I want to be able to mount my TV on the breast, will I need to add some extra batons for strength? The chimney breast is for a wood burning fireplace.
PC Pro, DIY Noob
wedge22 is offline   Reply With Quote
Old 06-04-2009, 06:29 AM   #2
A good rotary hammer set to chisel is the best way to remove a layer of stone/brick. You will need something to nail the drywall to, and it can also serve as an anchor for the TV. It needs to be well anchored to the chimney structure, and spaced as needed for the TV supports. You should have the specs before you install the furring. Check local codes concerning the fireplace. There are usually clearance requirements for any combustible near a working fireplace.
Old 06-05-2009, 01:29 AM   #3
Here is a technique that may work out for you.
I use slightly smaller globs of plaster and space them a little closer. They sell bonding plaster, for this application.
Bigfoot is offline   Reply With Quote
how to make waterfall with fake rocks ponch37300 Landscaping & Lawn Care 11 05-22-2009 01:04 PM
How should a fake stone fireplace be finished witrucker General DIY Discussions 2 01-26-2009 01:16 PM
Masonry Stone Archway jp33 Remodeling 8 01-31-2008 06:23 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
