Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-28-2011, 10:42 PM   #1
Removing a drywall ceiling
I have a dry wall ceiling that may have some hidden cables; what is the safest and most efficient way to remove this dry wall?
manuel velez is offline   Reply With Quote
Old 03-29-2011, 07:41 AM   #2
Dust mask, gloves, eye protection, and a wonder bar. Start a hole and pull. If it is under an attic, it will be MESSY(insulation). Don't go sawing if there may be wires.
But why pull it down, is there a problem with the drywall??? Drywall dings, holes are easy to patch.
Old 04-08-2011, 09:58 PM   #3
I like to use a Sazsall with a modified blade. Break the blade so only a half inch or so of stroke is made. You can cut right over studs and joists and not cut through to wires and cables behind.
Bring it down is good sized pieces to minimize the handling and trips to the dumpster.
____________
Vince
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Using drywall for Drop Ceiling rickkeeter Drywall & Plaster 8 02-13-2009 08:52 AM
Plaster Ceiling and drywall dprasan Remodeling 6 02-06-2008 12:34 AM
