Removing The Door Frame, Fixing The Opening. - Remodeling - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 02:19 PM   #1
Removing the door frame, fixing the opening.
So im remodeling this apartment i bought, and one of the things i did was to remove the old door frame as it looked horrible, and there was no door on the hinges anyway. My plan is to open it up a bit, so i dont really want to replace it with another casing, i just want to even it out and have a bigger opening.
Problem is, the wall behind the casing was really pourus and crunchy, so when i removed the casing it left a lot of holes and dents on the surface behind it. Ill have added pics below.
What is the best way to even it out? should i simply remove everything down to the brick and put wooden boards with the right dimensions over it, fill in the cracks with grout and then paint? Or should i salvage what i can from whats left from these surfaces? There are a lot of cracks in the rest and large chunks are hanging lose, so im wondering how to approach this. Any help would be appreciated.
Krudus is offline   Reply With Quote
Old 02-28-2013, 07:36 PM   #2
Rewards Points: 150
Is this basement, are all walls in house concrete, is that structural wall?
kaschmid3 is offline   Reply With Quote
Old 03-03-2013, 09:43 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
your best bet is to add a boxed door frame around the opening without a door added. it will cover all of the ugliness of the busted concrete,
just make sure to match what is in the rest of the house so it does not stand out. not sure if you should try and open that up anymore than it is
looks like it could be a structural wall...
hand drive is offline   Reply With Quote
spacer b/ween entry door and opening amakarevic Windows and Doors 1 06-01-2012 04:10 AM
Old roof opening mystery Mike in Arkansas Roofing/Siding 10 03-23-2010 06:19 AM
Getting a furnace through a narrow opening? Sowchoy HVAC 3 02-15-2010 07:55 PM
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 03:46 PM
Framing Opening Length captainron19 Carpentry 3 04-01-2006 10:50 AM
