Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-13-2008, 11:15 AM   #1
Removing corian countertops
I'm ready for my kitchen demo- removing cabinets & countertops. I know that corian dust is nasty so request advice on cutting & sledgehammering. What kind of saw blade is best ? Should I just "have at it" or should I plan the destruction- best place to start etc.? Thanks.
stan 41943 is offline   Reply With Quote
Old 03-13-2008, 12:24 PM   #2
Could you pry it off and then sell it or give it away?
pcampbell is offline   Reply With Quote
Old 03-13-2008, 04:10 PM   #3
Sorry to say it needs cutting before I pry.
Old 03-13-2008, 09:39 PM   #4
Cabinet Installer
Dansbell's Avatar
You may be surprised at how easy it is to break it apart. Look at the back splash. Is it a separate piece from the counter? If so, start by prying them off the wall. Inside corners are weak points. I would start by prying up on the end of your longest run.
Cutting will make a mess and odor. If you can hang plastic you can limit the travel of the dust. As far as a saw blade is concerned, It will cut easily with any wood blade.
If you are not concerned with salvaging the tops, I would start with a hammer around the sink or corner, and just break it up. It is likely glued down and will break when you start prying anyway. The mess will be greatly reduced. Remember it may break into sharp pieces. Be Careful.
I may recommend a jig saw or Sawzall if you decide to cut it apart. The dust would be reduced when compared with a circular saw.
Good Luck.
Daniel S. Bell
Belbuilt, LLC
Cabinet Installation Medford, Oregon
Dansbell is offline   Reply With Quote
Old 03-14-2008, 06:47 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Another suggestion, regarding the dust:
When you cut the counter, have someone else standing near you, with a shop-vac. Have them hold the shop-vac hose and straight wand, up to the saw, behind the area, where the dust issues from. It will suck up 90% + of the dust, while you are cutting.
Corian is stated as being "minimally" toxic.
I'd still suggest wearing good dust masks or respirators.
FYI:
White pages: http://www.parksite.com/productgroup.../msds_3_42.pdf
MSDS Sheet: http://www.parksite.com/productgroup.../msds_3_40.pdf
- Build Well -
Old 03-14-2008, 07:14 AM   #6
Gentlemen- thanks so much for your thoughtful advice. Took off backsplash, made cuts with jig saw at the U's and pryed it off. Easy !!!!!!!
Corian or Granite counter tops Jms92 General Discussion 21 04-17-2010 07:18 PM
Granite Countertops and Restaining kennykenny Remodeling 64 05-02-2009 12:15 AM
Install granite countertops first or stone backsplash?? ncoppola09 Remodeling 32 02-20-2007 02:00 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
