Removing Contruction Glue From Dry Wall - Remodeling - DIY Chatroom Home Improvement Forum
Old 06-07-2008, 03:07 PM   #1
Removing contruction glue from dry wall
I have removed old wainscotting in my dinning room and have found that it was applied with both nails and construction glue. How can I remove the left over glue from the dry wall ? I am trying to scrape it off but it seems to be taking the paper off the dry wall also ! How can I remove the glue with minimal damage to the wall ??? I am lost.
old&bald is offline   Reply With Quote
Old 06-07-2008, 03:46 PM   #2
You can't. Construction adhesive was made to bond with porous materials. You may get lucky with a very sharp scraper blade, but you are still going to have a little damage you'll need to fix.
jerryh3 is offline   Reply With Quote
Old 06-07-2008, 11:11 PM   #3
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 850
You might need some of this stuff.
PrepRite drywall conditioner:
Penetrates, seals damaged or torn drywall
Eliminates paper bubbles caused by patches and skim coats
Anchors loose paper fibers for easy sanding
Low odor acrylic latex formula
Then skim coat affected areas w/ joint compound.
Sir MixAlot is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Removing a (block) wall - questions Genhawk21 Building & Construction 3 09-08-2007 07:26 PM
Removing Texture From Interior Wall JustWondering Remodeling 3 05-28-2007 06:56 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
