Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 08-28-2009, 11:52 AM   #1
Removing concrete stone from fireplace - Need How To Advice
I want to tile my fireplace with slate. There is currently older blocks of stone or rock on the fireplace. My options are to remove the blocks or go over the blocks with tile. The blocks are un-even so tiling over them may be difficult. How would I remove the blocks? It is a see through fireplace.
cheese1478 is offline   Reply With Quote
Old 08-28-2009, 02:18 PM   #2
elec chipping gun & brick chisel,,, also a point bit,,, all avail at your local rental store !
itsreallyconc is offline   Reply With Quote
Old 08-28-2009, 02:46 PM   #3
TooledUp
I agree on the electric chisel. I have also seen people add a small wall around the original fireplace--if you have the room.
TooledUp is offline   Reply With Quote
Old 08-29-2012, 10:02 AM   #4
For me it wasn't that hard to remove the brick. We have it down to the framing that was put around the insert itself. We have to replace the dry wall on the side and backer board on the front where we are going to put marble.
I did the removing of the brick with no problem. Large hammer and chiesel.
Susielane is offline   Reply With Quote
culture stone fireplace takaya Carpentry 0 10-09-2011 12:17 AM
What correct mix for building a stone foundation wall? & correct mix for stone fireplace. world travler Building & Construction 0 08-04-2011 07:39 PM
Mounting a TV on a stone fireplace christymichael General Discussion 5 03-09-2011 01:01 PM
New Fireplace Insert w/ Stone Veneer cumak Building & Construction 3 07-02-2010 12:04 AM
Hanging drywall around stone fireplace. kossuth Drywall & Plaster 1 06-04-2010 08:24 PM
