Removing Calcoat Reinforcement Metal Mesh - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 11:34 AM   #1
Question
Removing calcoat reinforcement metal mesh
Hi. I'm new to this forum.
I'm tearing out my son's ceramic tile bathbay, due to moisture problems. It is all calcoat and is a bearcat to remove, except for the really rotten parts. I need some advice as to the correct procedure for mating the new sheetrock/tileboard wall to old calcoat one. Also, how to cut metal reinforcement mesh off neatly, without damaging old wall.
Thank you!
Tudy is offline   Reply With Quote
Old 07-05-2010, 04:23 PM   #2
Rewards Points: 5,336
If the walls are at two different planes, you build one out. To cut the metal, pick up a 4 1/2" grinder with a few metal composite blades and a pair of goggles. You can also use tin snips if you're into manual labor.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Tudy (07-05-2010)
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 01:23 PM
Removing tar from PVC stink pipes & metal vents? echase Roofing/Siding 4 04-06-2010 06:20 PM
Removing Wire Mesh And Scratch Coat/Mortar atw58 Flooring 2 07-25-2009 09:44 PM
Do I need mesh reinforcement for a 2 1/2" mud bed? jayp Building & Construction 1 06-11-2008 11:44 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
