Removing Brick Around Kitchen/fireplace - Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 08:25 AM   #16
Rewards Points: 558
Yeah if you use a brick chisel and a 5# hammer remember to wear safety glasses and work gloves. This is probably the easiest and most manageable way for a do it yourselfer to do the job without making a big mess. Just make sure you either have a dumpster on hand to dispose the brick or have another use for it somewhere else like edging around your path or garden etc.
The bulk of the demo you can do yourself and save $$ but if your not comfortable with the rest well at least it will be all open for the proper trade to give you a quote on what needs to be done when everything is in the open.
epson is offline   Reply With Quote
Old 03-10-2011, 08:43 AM   #17
fyi - I took the brick to a concrete crushing facility near me. They used to charge me $10 bucks. This last time I went, there was no cost to dump some concrete I had from a basement bathroom rough in.
Worth checking into.
ferris13 is offline   Reply With Quote
Old 03-10-2011, 08:49 AM   #18
Learning by Doing
Leah Frances's Avatar
LUCKY. At our Solid Waste Facility all construction debris 58$/ton 5$ minimum for residents. It's not super pricy (I've maybe spent $600 in the last 4 years) but it's the 35 minute drive to the landfill that kills me.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-10-2011, 09:13 AM   #19
Rewards Points: 118
Forgive me if I have missed something, but I have looked through the posts a couple of times, and am still wondering. Where does the chimney from the wood burner lead? Where is the furnace stack? Do you have a brick chimney extending above your roof line? What do you have in the attic above this area? My point is that, for the most part, I agree that the brick was extended along the wall as part of the interior decor, but is some of it also functional? If it is in fact all decoration, a masonry chisel, heavy hammer, heavy gloves, and safety glasses and/or goggles, as Epson descibed, will work fine. Once you get a few of them loose, it moves along much better. I would also set up something to flying debris, and at least some of the dust, such as sheets of plwood or OSB, a tarp, or even some heavy plastic would help.
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Removing alcalde paint off brick handycanuck Painting 0 06-18-2010 09:50 AM
removing paint from interior brick? suzan30 Remodeling 4 01-05-2010 04:05 AM
Removing brick pole in garage Matthew de Beer Building & Construction 2 09-14-2009 08:02 AM
Removing a brick veneer Bayou Woman Building & Construction 6 06-02-2009 05:21 PM
