Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 03-07-2011, 08:44 PM   #1
Smile
removing brick around kitchen/fireplace
Hi i'm wondering if anyone has any ideas about the best way to proceed with removing brick in the kitchen area/fireplace area (it is a woodburner stove, not an actual fireplace) should i just attack with a sledgehammer and redrywall the drywall that is behind it, or is there a better way? i have some electrical in this brick also. i also have a heating duct.
thinking of hiring a contractor just so it will get done faster. any ideas? any input appreciated!
kabergeron is offline   Reply With Quote
Old 03-07-2011, 08:51 PM   #2
Learning by Doing
Leah Frances's Avatar
A picture and some more explanation would help us help you.
- What's your goal?
- Is the wood-burning stove staying?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-07-2011, 08:57 PM   #3
Tileguy
Bud Cline's Avatar
Need a picture of this one.
Don't get in a hurry just yet.
Old 03-07-2011, 09:00 PM   #4
ok let me go take a couple pics. will upload soon, i could use the advice!
Old 03-07-2011, 09:10 PM   #5
Learning by Doing
We're very good at helping. We just need sufficient information.
Old 03-07-2011, 09:41 PM   #6
ok, here are some pics.
the old country stove / oven / and wood burning stove all are going also.
we are looking to have it look more modern, and consider the brick and these iron pieces quite dangerous for our little guy who is quite the adventurer. (their is currently carpet foam velcroed to the brick on the floor)
it is about 8 feet, floor to ceiling in kitchen behing stove and around oven, and then adjacent in living room, about 5 ft long on two sides going about 5' high with a base for the fire stove.
thanks for any ideas. is this a DIY? or hire a contractor? it seems like a couple guys could clean it up in a day, i'd like it done like that quickly so all dust is removed and cleaned up and redrywalled or maybe the same drywall but i figure it would get damaged, so we can resume living in the area. we'd also like to extend the door way between the two rooms while we're at it , from 29.5" to 48" so we can put in french doors. that is where two electrical outlets and a switch are, i figure it shouldn't be difficult to just have them moved further in the studs where the wall will be?
removing brick around kitchen/fireplace-pic_1899.jpg   removing brick around kitchen/fireplace-pic_1904.jpg   removing brick around kitchen/fireplace-pic_1907.jpg
Old 03-07-2011, 10:02 PM   #7
Tileguy
Bud Cline's Avatar
Looks like a lot of brick. Is there some kind of a foundation supporting that mass?
Old 03-07-2011, 10:09 PM   #8
well this is kind of in the middle of the house. the electric stove is on a brick base about 4 inches high, then just a small counter before the oven section, i think all the brick is decorative and has drywall behind it best i can tell. house is over a crawl space, as i recall from being down there, i don't believe their to be anything special supporting the brick itself. and i wouldn't think the brick is supporting anything. i guess our concern would be the extending of the doorway if that is supporting something.
Old 03-07-2011, 10:17 PM   #9
Tileguy
Bud Cline's Avatar
Maybe I should ask...
Is this "real" full dimension brick. Or is it some type of a "thin-brick" application. It looks like the real McCoy from here.
Old 03-07-2011, 10:37 PM   #10
brick measures about 3 " wide by 8 to 8 1/4 " long. i don't think it's a fake brick, lot of mortar in between.
Old 03-07-2011, 10:44 PM   #11
Tileguy
Bud Cline's Avatar
I don't either.
Do you have any big hammers? I mean like a 3# or 5# sledge?
If your serious about this, you could go to whacking on that corner and see if you can loosen-up a few brick to see what's there. Don't go too far.
If you proceed...start at the top and work down of course.
Old 03-07-2011, 10:51 PM   #12
i don't have a sledge but was thinking of getting one to tackle this.
reason for contractor i think would be speed, and not sure what to do with heating duct or electrical. and to re-drywall.
i've done most of the home improvement since we bought the house, but i think this project might be one worth paying for if the price is right. not sure what this job would go for, will have to get a couple quotes, would like it done asap.
Old 03-07-2011, 10:57 PM   #13
Tileguy
Bud Cline's Avatar
It's going to be a lot of work actually. Bunch of dust too.
Old 03-10-2011, 08:48 AM   #14
I used a wide mason chisel (they have some that have a hard plastic hand guard, jic you miss...ouch) and mini-sledge when I removed a few courses off my fireplace.
I set the chisel under the lip of the brick and swung upwards. Of course I had a better startig point given it was a mantel and not bricked to the ceiling. I was able to remove one course at a time and it was very manageable.
With the chisel you can better manage where the break will occur instead of just swinging away with a sledge. I would be worried about moving the wall and cracking the drywall joints etc of anything that may be adjacent.
ferris13 is offline   Reply With Quote
Old 03-10-2011, 09:00 AM   #15
Learning by Doing
Don't forget to plan for disposing all that brick and mortar. Chances are, you can't just put it out with the trash. Salvage the bricks? And use them in your yard?
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 09:50 AM
Removing alcalde paint off brick handycanuck Painting 0 06-18-2010 10:50 AM
removing paint from interior brick? suzan30 Remodeling 4 01-05-2010 05:05 AM
Removing brick pole in garage Matthew de Beer Building & Construction 2 09-14-2009 09:02 AM
Removing a brick veneer Bayou Woman Building & Construction 6 06-02-2009 06:21 PM
