Removing Aluminum Columns - Remodeling - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 12:19 PM   #1
removing aluminum columns
How do you release the catch (tongue and groove?) on aluminum columns? would like to remove them without tearing them up.
coulty1 is offline   Reply With Quote
Old 04-08-2012, 11:36 PM   #2
General Contractor
do you have pictures?
KennMacMoragh is offline   Reply With Quote
Old 04-09-2012, 07:58 AM   #3
Rewards Points: 6,652
If they are like duct work, you have to press in near the seams to do it. But most likely these columns were pressed together and spot welded or glued at the factory, and there will be no way to do it.
Old 04-09-2012, 11:40 AM   #4
What are they holding? Can you slightly raise the load with a jack pole and slide them out? What are you replacing them with to support what they held up? I suppose you could cut an inch off the top and remove them that way.
Evstarr is offline   Reply With Quote
Old 04-10-2012, 08:49 AM   #5
Rewards Points: 2,238
If they're the kind of columns that I think they are -
once they're snapped together -
they're "rather", difficult to take apart!
However, as "Evstarr" says - you may be able to jack up the beam (load)
and slide them out.
They may have some type of post inside them (Steel, wood ...) -
that will make things more, difficult!
rossfingal
Yeah - pictures!
rossfingal is offline   Reply With Quote
Strapping Aluminum Columns to Concrete Slab chall Building & Construction 2 01-16-2012 10:16 AM
Removing latex paint from aluminum mill finish window frame pretzels Painting 6 03-31-2011 10:39 PM
Removing lally columns tbone128 Carpentry 3 11-14-2007 09:02 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
