Removing 9" X 9" Floor Tile - Remodeling - DIY Chatroom Home Improvement Forum
Old 10-07-2007, 06:41 PM   #1
Removing 9" x 9" floor tile
I have a room in my basement that has the old 9x9 tiles on the floor. They are in bad shape, and brittle. I want to remove them and just paint the floor. What I don't know is whether or not they contain asbestos. I am going on the assumption that they do. I can remove the tiles easily without breaking them by applying a little heat from a heat gun. Is there anything that I should be doing from a safety standpoint other than wearing a HEPA respirator? I'm not raising any dust.
Mikon is offline   Reply With Quote
Old 10-08-2007, 12:45 AM   #2
Rewards Points: 5,336
You might have an issue with the remaining adhesive on the floor. Some tiles used an asphalt based adhesive to install them. Paint compatibility could be troublesome.
Ron
Old 10-08-2007, 07:22 AM   #3
You probably are right Ron, the adhesive is black in color. Does anyone have any success painting the black adhesive left on the floor after removing 9x9 floor tiles? It is well adhered. Thanks, Mike
Old 10-10-2007, 10:38 AM   #4
I would inquire at your local paint store.
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
removing knockdown texture K_I37 Painting 7 05-07-2006 02:23 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
