Removed Garage Door From Shed, Need Ideas To "patch" Hole. - Remodeling - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 02:31 PM   #1
Rewards Points: 408
Removed garage door from shed, need ideas to "patch" hole.
It didn't work and I needed to get it open to get large tools in so I just removed it. Since it would be hard to match the siding what should I do to fill this hole? I was thinking french doors and a ramp but what else around it to make it look good?
RyanD is offline   Reply With Quote
Old 05-20-2013, 02:38 PM   #2
Rewards Points: 14,312
What makes you think the siding would be hard to match?
I'd install a steel double door.
Old 05-20-2013, 02:39 PM   #3
Rewards Points: 408
Just because it's been there for a decade and faded. I'm also thinking of cheaper ways to do this projects and matching the siding sounds expensive. :-)
Old 05-20-2013, 02:45 PM   #4
You could reframe that whole opening and go over it with new siding for about 1/2 of what one french door would cost.
Old 05-20-2013, 02:47 PM   #5
Rewards Points: 408
I need a big opening to get tools in and out. Alternatives?
Old 05-20-2013, 02:58 PM   #6
Rewards Points: 81
Build your own double doors, you can make them look as good/bad as you want/can.
one cut is offline   Reply With Quote
The Following User Says Thank You to one cut For This Useful Post:
mae-ling (05-20-2013)
Old 05-20-2013, 03:30 PM   #7
Rewards Points: 408
Looking at that it would be great if I could build a ramp-door. The door swings from the bottom to create a ramp when open. :-) I guess that would be a heavy door though.
Old 05-20-2013, 05:27 PM   #8
Rewards Points: 2,212
easier/cheaper to build a separate ramp and a double door.
mae-ling is offline   Reply With Quote
Old 05-20-2013, 06:07 PM   #9
Anyone here ever seen a DIY build door that was not rotted out and falling off the hindges after a few years?
Old 05-20-2013, 06:25 PM   #10
Rewards Points: 81
Although I am a carpenter by trade, so not really DIY jobs, I have built 2 that are still in prime condition after 4 or so years and I live in one of the wettest windiest places in the country. Just think before you build and there is no reason why you cannot do it too.
Also, i like the OP idea of a drawbridge style door. Go for it.
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Has anyone built a shed as an extension to their garage? CoconutPete Building & Construction 5 03-31-2010 08:54 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
