Remove Wallpaper - Remodeling - DIY Chatroom Home Improvement Forum
Old 09-11-2011, 11:06 AM   #1
Remove Wallpaper
I need help in removing wallpaper in kitchen that was installed in 1983
I have never removed wallpaper
thank
Faye
Faye Hays is offline   Reply With Quote
Old 09-11-2011, 01:17 PM   #2
Civil Engineer
Rewards Points: 4,790
Go to any big box store and buy a can of wallpaper remover. Follow directions very carefully, and be sure to wear a respirator, that stuff is NASTY (I know, I removed wallpaper recently in my living room). but it works. Make sure you wear appropriate gloves, bad news on your hands.
Daniel Holzman is online now   Reply With Quote
Old 09-11-2011, 03:48 PM   #3
m1951mm's Avatar
I have removed hundreds of yards of wallpaper with using HOT water and vinegar as my tools. The hard part about removing wallpaper is getting the adhesive off the wall prior to painting The paper itself is not the issue. Once you wet down the paper it will come off with some PATIENCE. The problem with wetting the surface is gouging the surface of the drywall behind it. I like to use a 4" mud/spackling knife but holding it at at close degree with the wall, not pushing into the wall, but more a scraping push motion.
I will suggest that you change this question to the Painting section on this site for even better information. The painters and wallpaper people hang out there more than this section. Post your questions there, or even do a search, I know there is alot of information on how to deal with striping and then painting afterwards!!!!!!!!!
GooD Luck, See you in the Painting Section!!!!!!!!!!
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
Faye Hays (09-11-2011)
Wallpaper Removal Choices in Kitchen LeviDIY Painting 14 12-02-2011 03:30 AM
Wallpaper removal or primer? Should I put up new wallpaper instead? Aqua Painting 1 04-06-2011 04:36 AM
Remove wallpaper from plywood Metra Drywall & Plaster 2 03-26-2011 08:19 AM
To remove wallpaper or just re-drywall interplexr Painting 12 01-14-2010 12:48 PM
Using Steamer to remove old painted over wallpaper saggdevil Painting 15 06-14-2009 05:22 AM
