-   -   Remove half walls & replace with wood railing/balusters (http://www.diychatroom.com/f15/remove-half-walls-replace-wood-railing-balusters-74973/)
jjgoss 06-29-2010 12:18 PM
6 Attachment(s)
Hi - I'm debating whether to do this myself depending the cost estimates.
Here's my situation:
1) I am handy but have never knocked down walls and put up railings
2) I have attached pictures of the walls that I want replaced with iron balusters, wood hand rail (on top of balusters) and wood bottom frame (on bottom of balusters)
3) There are four separate areas that I hope to replace with the balusters and wood railings:
I have attached the pics with the proper names of where I would like the railings to go in this 3 story townhome:
- First floor 70 inch wall section. The whole wall is 191 inches but the railing cannot go across because of the stairs going to the second floor
- First floor 48 inch wall section. This section of the wall is by the stairs going up to the second floor.
- Second Floor 120 inch wall that is the wall at the top of the staircase
- Entrance Floor (the bottom floor is the garage) 27.5 inch wall this is right at the entrance of the front door. This staircase leads up to the First floor.
I am interested in using selected the iron balusters. What do you all think about repeating 3 styles: PC 8/1 (single 24"), PC 6/1 (single basket), PC 6/4 (double basket)??
If that's too much in a short area then how about repeating PC 8/1 (single 24") and PC 6/4 (double basket)??
Also, I am planning on replacing the carpeted floors with wood laminate and replacement carpet for the stairs. I need to get the stair railings completed first before I do all that correct?
Also, if possible, I need a referral for a local Tampa, FL person that can handle the removal of the walls as well as installation of the railings.
Thanks all in advance for your help and suggestions! JJ
Willie T 06-29-2010 03:10 PM
First, have you determined if any part of that wall is a bearing wall supporting any portion of your second or third floors?
And yes, I can recommend a good contractor in Plant City. He works a lot of commercial jobs in Tampa.
jjgoss 06-29-2010 03:52 PM
Thanks, Willie for your thoughts.
My intent is to remove sections of the walls that are not load-bearing on the first floor and replace with railings.
Would your friend by interested in looking at the pics in my thread and emailing me at least guidelines on what a reasonable cost to remove the walls and replace with balusters and railings. I already have an idea of the the approximate cost of materials, but would be interested in any thoughts on labor costs. jjgoss@yahoo.com
railman 06-29-2010 08:05 PM
Job looks pretty simple, except for light switches in the upper half wall. The job would however be VERY involved, if I were to do this bid this job it would be pricey. By the way for metal balusters in wood rake rail I figure wood job rate x3, level rail x2.
