Remove Door Frame - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 12:45 AM   #1
Remove Door Frame
Getting a closet insert custom built and am in the process of removing existing door frame. The carpenter needs the header, top plate and a portion of the wall removed and backed up basically to the king studs. I've exposed everything I need to, but one of jack studs and top plate is partly recessed into the sheet rock. Any tips for getting these out cleanly?
Door Frame
Closeup of top left corner
Top Plate
nymlake is offline   Reply With Quote
Old 11-05-2010, 12:50 AM   #2
jlhaslip's Avatar
Rewards Points: 396
drill a hole and use a sawzall
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
To remove or not to remove tar paper, that is the question Jeremy Hillary Boob, PhD Building & Construction 4 02-27-2011 09:34 PM
Cannot remove haze from tile grout Woody36 Flooring 1 10-12-2009 09:54 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
Need to remove toilet temporarily pomelo Plumbing 4 08-22-2009 05:39 PM
Remove Joist Bridge?? busy1 Building & Construction 9 09-01-2008 10:56 PM
