Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-07-2012, 06:00 PM   #1
Remove and Close In Exterior Door Opening
I need to remove a 30" exterior door then close in the area so drywall and vinyl siding can be installed over it. Can anyone tell me what material/tools I'll need and what steps I need to take to get this done properly? I'm not concerned about the drywall & siding installation at this point - closing the opening is the priority right now.
Thanks in advance.
DIYerIT is offline   Reply With Quote
Old 09-07-2012, 06:05 PM   #2
Remove trim and door, set a bottom plate, install another stud set at 16" or 24", insulate, on the outside add sheathing and house wrap that over laps old house wrap.
Remove siding anywhere around the door and install new siding.
Use whole sections not just cut it and patch it.
Old 09-07-2012, 06:24 PM   #3
Thank you joecaption. If you could help me again I'd appreciate it:
1. Should I cut the stud, plate, & sheathing the exact size of the opening or a little larger to get a tight fit?
2. Is there a certain size and type nail I should use to secure everything?
3. Is it OK if the nails are installed at an angle into the existing framing?
4. Is there a minimum number of nails I should use, especially on the sheathing, or just nail until nothing moves?
Old 09-07-2012, 08:15 PM   #4
I'm not Joe, but tapping things in place is fine; if you have to beat any of the pieces into place, it's time to cut them again, or you might move something that you don't want to move. I would use 10 pd coated for the framing and 8 pd coated, spaced 6 - 8" for the sheathing.
Old 09-07-2012, 08:31 PM   #5
I appreciate your answer nonetheless DexterII. That information is very helpful and what I needed to know.
Close off a doorway with drywall that has corner bead. Remove or mud over? cmgraue Drywall & Plaster 4 02-01-2012 04:00 PM
Remove and close off old stove hood venting Chickylala Kitchen & Bath Remodeling 1 09-09-2011 02:02 PM
Remove and close a window permanently Tomperro Windows and Doors 3 04-06-2011 04:46 PM
How to remove Built-in Electric Fireplace Almighty Building & Construction 1 11-12-2009 06:18 PM
Window won't close completely bucksone General Discussion 3 06-25-2009 06:57 AM
