Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 10-07-2011, 06:13 PM   #1
Removal of interior walls
I am considering knocking down a few walls to accommodate a major renovation. I assume I'll need a structural engineer??
If so can anyone suggest one in oakville Ontario area or can a general contractor accommodate this?
Kipster is offline   Reply With Quote
Old 10-08-2011, 12:02 AM   #2
Moderator
Welcome to the forum!
This is a do-it-yourself forum to help you do it yourself....... we can hep you there.
Ask locally.
Gary
Clothes taking longer to dry?
Old 10-10-2011, 07:50 AM   #3
If you can't tell if a wall is supporting or not, yes, you need someone that can.
Old 10-10-2011, 07:58 AM   #4
How can I tell if a wall is a supporting or load bearing?
Old 10-10-2011, 08:32 AM   #5
Civil Engineer
The definition of a load bearing wall is one that supports more than its own weight. In order to determine if a wall is load bearing, you need to look at the framing above the wall to determine if any vertical load from above is transmitted downward through the wall. If you have plans for the building, you can determine which walls are load bearing by reading the plans. If you have no plans, you may be able to tell from exposed framing elements.
If the framing elements are not exposed, you are almost certainly going to need to open some holes to examine the framing. There are special cameras that work on the end of long, flexible, thin tubes that let you peer around through very small openings, and the pros often use these to do things like check for leaks, look for mold, or examine framing, through small openings that are easily patched.
Old 10-10-2011, 08:35 AM   #6
Super Moderator
You will need to take pictures of the outside of the house---the attic---the second floor--the first floor and the basement----a sketch will help---then we will have something to talk about.
Walls above basement beams are often load bearing---Center walls are sometimes LB walls--
We need more info. And someone with structural knowledge on site must verify our thoughts.-Mike--
prepping walls after wallpaper removal.... diy'er on LI Painting 10 11-09-2010 09:57 AM
Removal of underlayment under toe space eyeglass Flooring 10 08-26-2009 05:59 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 01:04 PM
