-   -   Removal of interior walls (http://www.diychatroom.com/f15/removal-interior-walls-119475/)
Kipster 10-07-2011 06:13 PM
I am considering knocking down a few walls to accommodate a major renovation. I assume I'll need a structural engineer??
If so can anyone suggest one in oakville Ontario area or can a general contractor accommodate this?
Gary in WA 10-08-2011 12:02 AM
Welcome to the forum!
This is a do-it-yourself forum to help you do it yourself....... we can hep you there.
Ask locally.
Gary
Just Bill 10-10-2011 07:50 AM
If you can't tell if a wall is supporting or not, yes, you need someone that can.
Kipster 10-10-2011 07:58 AM
How can I tell if a wall is a supporting or load bearing?
Daniel Holzman 10-10-2011 08:32 AM
The definition of a load bearing wall is one that supports more than its own weight. In order to determine if a wall is load bearing, you need to look at the framing above the wall to determine if any vertical load from above is transmitted downward through the wall. If you have plans for the building, you can determine which walls are load bearing by reading the plans. If you have no plans, you may be able to tell from exposed framing elements.
If the framing elements are not exposed, you are almost certainly going to need to open some holes to examine the framing. There are special cameras that work on the end of long, flexible, thin tubes that let you peer around through very small openings, and the pros often use these to do things like check for leaks, look for mold, or examine framing, through small openings that are easily patched.
oh'mike 10-10-2011 08:35 AM
You will need to take pictures of the outside of the house---the attic---the second floor--the first floor and the basement----a sketch will help---then we will have something to talk about.
Walls above basement beams are often load bearing---Center walls are sometimes LB walls--
We need more info. And someone with structural knowledge on site must verify our thoughts.-Mike--
