Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 05-28-2008, 11:59 PM   #1
Remodelling Family room
I am currently remodelling my family room and am going to use Beadex Bullnose corners, I want to use the Beadex 2 Way Corner Cap, could someone explain how I should install these. Thanks in advance...........scotty
scotty47 is offline   Reply With Quote
Old 05-29-2008, 05:34 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Spray Adhesive for Drywall Corner Bead. Examples:
http://solutions.3m.com/wps/portal/3...=1114284885347
http://www.trim-tex.com/catalog/finishtool.htm
- Build Well -
Old 05-29-2008, 08:45 AM   #3
Thanks or the reply AtlanticWBConst, I will have a look at that, I only have 3 corners to put on..............scotty
Old 05-31-2008, 01:41 AM   #4
One more question please, are these Bullnose Caps paintable or do I have to build up mud on the corner. Thanks again.............scotty
Old 05-31-2008, 06:58 AM   #5
They are paintable as they are.
- Build Well -
Old 05-31-2008, 09:04 AM   #6
Thanks you again for your reply AtlanticWBConst, one more thing these new ( to me anyway ) beadex metal with paper on inside corners, do you still do one side at a time and wait for it to dry, or can you do both sides .
Thanks..........John
Old 05-31-2008, 09:49 AM   #7
You install (apply) it by setting both sides of the paper edges as the same time using compound. Once applied, coat one side and allow it to dry. When dry, scrape down any crusty lumps or waves, and then coat the opposite side.
- Build Well -
Old 05-31-2008, 09:53 AM   #8
Thanks again AtlanticWBConst, have to go to work but will start on the mudding tommorow...............scotty
Old 06-08-2008, 12:00 PM   #9
I finished my drywalling project and it looks great. Now that I am ready to put my suspended ceiling back up I am looking for Bullnose corner covers for the angle moulding, Armstrong make a couple of different ones, there part numbers are 7864,7866. I can only find the square ones here in my town, would anyone know where I could get these.
Thanks again.................scotty
More On This Topic
Hi! I’m John Armstrong with expertvillage.com. I’m a professional guitar instructor and today we’ll be going over the 12 string guitar. Okay, another thing that’s really cool to do on a 12 string that sounds real nice is the use... Read More »
Hi I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. After your drywall has been taped and textured it's ready to cover up with paint, which is the next step. Painting is another job that a lot of homeowners... Read More »
Using full sheets of drywall--also called sheetrock--is recommended whenever possible, but designing a project perfectly around the standard size of a sheet of drywall isn't that easy. So measuring when installing drywall and cutting the sheet to your... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
So we're back at the Vine Ridge house and it's really exciting because, now we've got the walls off and we can see what's behind. We had some exciting things evolve. As I was leaving the property, I noticed that there was a second story window and I... Read More »
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Family Room Color / Giant Brick Fireplace kashimama Interior Decorating 3 12-25-2007 03:42 PM
Plasma Mount in Family Room Built-Ins taysdad Home Theater 3 09-24-2007 09:59 AM
Family Room Project ktkelly Project Showcase 0 05-16-2007 09:48 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
