Remodeling Old House Lots Of Demo - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-30-2013, 09:28 AM   #1
Rewards Points: 156
Remodeling old house lots of demo
I'm planning to remodel a bungalow that was built in 1919. I'm doing some of it myself and some will be hired out. I'm doing only the kitchen and bathroom. The rest of the house was all redone 10-15 years ago and still looks great.
I'm planning to do a lot of demo myself. Does anyone know if houses built during this time used lots of asbestos? The walls have sheetrock over plaster & lathe in except for the exterior walls (removed so they could be insulated I believe).
I know that there are different types of asbestos. Was it common in plaster? I removed a few small areas to closely examine it. Looks like there's horse hair in it, too.
Thanks for the feedback.
strategery is offline   Reply With Quote
Old 11-30-2013, 09:54 AM   #2
Rewards Points: 12,794
Could be asbestos in the plaster and as insulation on the duct work if there is any.
Also surely lead paint.
Old 11-30-2013, 01:35 PM   #3
Rewards Points: 3,130
Short of having a sample or two tested, there's no real way to know if there's asbestos. And you really do need to know before you start ripping it out.
Old 12-03-2013, 01:06 AM   #4
Rewards Points: 156
If i do get it tested are all forms of asbestos equally unsafe? Would it rule out me doing it myself?
Old 12-03-2013, 09:02 AM   #5
The only "safe" residential asbestos is that which remains undisturbed. Regardless of whether it's in the plaster, floor tiles, tile adhesive, or wherever, disturbing it broadcasts particles which, when inhaled, are hazardous.
Were we talking about a commercial building, you would generally be prohibited by law from remediating the problem yourself; a licensed professional abatement company would have to do it. Residential is different, and depends on State and local laws. You might be legally able to do it yourself, or you might not. Even the places where asbestos can be disposed of are usually regulated. You need to check with your local authorities if you're entertaining any thoughts of DIY for this. Personally, if the tests were positive, I'd let the pros handle it. Unlike the scam that is radon remediation, the danger from asbestos is quite real.
Old 12-03-2013, 09:23 AM   #6
PoleCat's Avatar
Rewards Points: 1,638
Even if you are asbestos free I would recommend a good respirator over the paper mask. Plaster dust during demolition will be intense and takes quite awhile to settle.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
md2lgyk (12-03-2013)
Old 12-03-2013, 04:48 PM   #7
Forgot this part. I've done what you're planning only once , and never intend to do it again. If you have young children in your home, anyone with asthma, or a prissy wife, you really should consider the house uninhabitable during this work (and afterward until it's cleaned up).
Old 12-03-2013, 05:43 PM   #8
747
registered
747's Avatar
Rewards Points: 534
Hopefully those walls don't have it. If they do. There going to get DEEP into your wallet for cleanup.
747 is offline   Reply With Quote
Old 12-06-2013, 12:01 AM   #9
Rewards Points: 71
1919 is a little early for there to be a lot of asbestos around, but if the house has been remodeled a couple of times, then you probably will find some. Asbestos was in *everything* for a while; duct tape, linoleum, linoleum backing, tile, shingles, electrical insulation--and I'm sure there are dozens more categories I'm not thinking of off the top of my head.
The good news is that asbestos remediation is comparatively cheap and easy. If you *have* to do something yourself--which I don't recommend--make sure you keep the surface damp to keep airborne dust down. That's what I did while removing some old ducting. If you're demo-ing some walls, though, you should think about hiring somebody, unless that's just not an option.
If I were in your shoes, I'd be *much* more worried about lead-based paint. *Much* more expensive to abate, and more dangerous, in my opinion. Unless the bathroom's been redone in the last forty years or so, a house that old almost certainly has leaded paint in the bathroom. Actually, if you've got kids, I'd encourage you to take a couple of soil samples around the house and get those tested, too. I'd be surprised if there weren't elevated levels in the dirt.
Really, there's no way to know how involved or expensive this will be until you get some samples taken.
El Barbón is offline   Reply With Quote
Old 12-06-2013, 12:08 AM   #10
Rewards Points: 156
Lead in the soil around the house? How would it have gotten there?
Old 12-06-2013, 02:36 AM   #11
Rewards Points: 71
I would have asked the same question before we moved into our house. By the time we had the old paint stabilized on the outside, the lead level in our soil was hovering in the parts-per-300 range. I guarantee that if a house has been around since 1919, it's been re-painted once or twice. And the loose paint that either flaked off or was scraped off is sitting there in your dirt. Personally, if I bought a house--even a brand-new one--that was built on a site occupied for more than forty years or so, I'd have the soil tested, just to be safe.
Lead is one of those contaminants (like asbestos) that are extremely toxic, and also really easy to inadvertently expose yourself to. Fortunately, a few simple tests and precautions can really reduce your risk. First step is to get some samples tested. I don't know about the sheetrock, but horsehair plaster is probably asbestos-free. I'd be more concerned about what's hiding behind any tile you've got. Take samples of mastic, tile, linoleum and get 'em tested. If you're worried about the paint, take a couple paint chips in, too (just make sure you get all the layers of paint). Having samples checked is relatively inexpensive, and should give you a pretty good idea of what you're up against.
Remodeling old Bath with LOTS of Questions Trufans Kitchen & Bath Remodeling 3 04-29-2012 06:51 PM
1924 house remodeling pizzawm Introductions 3 04-27-2012 02:55 AM
Thinking About Buying A Larger House Houston Riverside Terrace Need Remodeling Ideas DJboutit General DIY Discussions 2 09-07-2010 06:25 PM
Old House - lots of Fixes adenardo Introductions 1 03-06-2009 05:20 PM
Patio roof to house attachment question mikemobile Building & Construction 1 09-30-2008 08:51 AM
