Remodeling Kitchen - Wall Must Go - Remodeling - DIY Chatroom Home Improvement Forum
Old 03-17-2014, 10:50 PM   #1
Rewards Points: 85
Hello everyone. I am in the preliminary stages of remodeling my kitchen. I am planning on removing the archway/wall separating my current kitchen from a small breakfast nook to open up the space. I was hoping you guys could give me an idea of what you think about this wall being load bearing. I am 90% certain it is only cosmetic as my next door neighbors (with the same 40's built cape cod) removed the same wall in their kitchen and also because the wall does not continue through the second floor into the second floor or the attic. Above it is a large closet where the closet wall does not line up with this one and below it does not continue into the basement. This wall runs parallel with the floor joists in the basement. I'm not sure if that is any indication like the roof trusses.
Whyjune1st is offline   Reply With Quote
Old 03-17-2014, 10:52 PM   #2
Rewards Points: 85
Old 03-17-2014, 10:54 PM   #3
Rewards Points: 85
sorry pictures did no load correctly
Tags
demolition , kitchen , load baring , removing , wall
Remodeling a 1920 kitchen fix what? Remodeling 10 06-20-2012 08:54 PM
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
Need advice on open wall kitchen width. mike44107 Kitchen & Bath Remodeling 3 01-26-2010 12:57 PM
Remodeling/ Removing a wall/ Load bearing?? hybridhatchc1 Building & Construction 3 01-22-2010 11:14 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
