Remodeling Kitchen - Remodeling - DIY Chatroom Home Improvement Forum
Old 11-06-2010, 06:53 PM   #1
Rewards Points: 119
remodeling kitchen
Can I lay tile over a Formica counter top or do I need to take it off first?
debd is offline   Reply With Quote
Old 11-06-2010, 07:28 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
The problem is if the formica ever separates from the substrate, your tile will be compromised.
You could try installing cement board over the formica as a new substrate for the tile.
tcleve4911 is offline   Reply With Quote
Old 11-07-2010, 03:11 PM   #3
Rewards Points: 5,336
Laminate is usually applied over flakeboard which is a moisture sensitive substrate. I'd check what you have before you invest any time and money.
Ron
Old 11-08-2010, 12:59 PM   #4
Ultimatetouch
Why not just go with granite. Its seemless and very cost effective if you hire the right guy. If you go with the tile becareful of the overhang area on top. Its raised where it goes into the over hang. Im not sure how that would work with the cement board or laying tile.
________________
Ultimatetouch
Kitchen Remodeling Company
ultimatetouch is offline   Reply With Quote
Old 11-08-2010, 04:53 PM   #5
Rewards Points: 119
We're planning on doing the work ourselves. It will be an odd shape with a 2 foot support wall coming through it so I doubt I could get the granite to fit the space (I also used granite for my bathroom, bought it from Home Depot. The claim was that it was sealed but it does get water spots on it that do dry out. Not sure I want that in the kitchen. I do like the way the sink attached to the granite is below countertop level instead of above it though) Haven't looked into it enough to know what you are referring to with the raised area going into the overhang. I do like the seamless idea though. One reason for going with tile is that the current Formica has gotten knife marks in it (even though everyone in the house says that they are using the cutting board). I could like something that will be more durable.
Old 11-08-2010, 07:23 PM   #6
Ultimatetouch
We're planning on doing the work ourselves. It will be an odd shape with a 2 foot support wall coming through it so I doubt I could get the granite to fit the space (I also used granite for my bathroom, bought it from Home Depot. The claim was that it was sealed but it does get water spots on it that do dry out. .
A good granite guy could install granite around anything. The guy will make a template to make the kitchen counter fit like a glove. As far as spotting and water goes, it depends on the type and color of granite used. Dark colors spot a lot. Somthing with colors and a lot of visual interest its usally harder to see any spotting at all. You could usually feel it though. Also years ago I priced granite vs. tile countertops when doing a kitchen remodeling project. They were about the same. Thats if your getting good tile. Also you will never get away from the joints and as you said the overmount sink. The overmount sink is a nasty little area to keep clean. We always seal the countertop after the granite is installed no matter what the case is.
___________________
ultimatetouch
Old 11-09-2010, 03:11 PM   #7
Rewards Points: 119
Still not sold on granite. Does anyone have a comment on using Quartz? Recommended? Not recommended?
Old 11-09-2010, 05:14 PM   #8
Quartz, like many granites, require sealing on a regular basis. They are also suseptible to scorching.
Tiling a counter has issues with grout discoloration around the sink and stove.
Ron
Kitchen remodeling appliance question dboston Kitchen & Bath Remodeling 7 10-29-2010 07:53 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Total remodeling of kitchen questions PARIS Flooring 3 05-28-2010 10:14 AM
Can I temporarily connect my dishwasher in utility room during kitchen remodeling? ilyaz Kitchen & Bath Remodeling 2 01-05-2010 07:24 AM
