Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 04-03-2008, 01:41 PM   #1
Remodeling Attic Space
I have alot of attic space that I'd like to utilize for storage. Currently there is no flooring in the attic, just the exposed insulation and joists for the ceiling below. Is it ok to lay plywood over to make floorboards? Or is this all left exposed for a reason?
jte1130 is offline   Reply With Quote
Old 04-03-2008, 01:51 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Assuming that the ceiling joists are greater than 2x4's, and that the joists there are placed 16" OC, or less, then you should be able to add plywood, for the area to serve as storage.
- Build Well -
Old 04-04-2008, 06:06 PM   #3
You may need to reroute electrical wiring as it might be laying atop the ceiling joists.
raam is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Flexible copper in attic space Lmiller Plumbing 1 03-11-2008 09:42 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
Birds' nest in attic crawl space Frances Pest Control 1 09-01-2007 05:48 PM
rats is my crawl space and in my attic this old house Pest Control 5 06-02-2007 06:48 PM
