Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 01-15-2011, 10:36 PM   #1
Remodeling advice wanted
Hello everyone, I am new to the site but i love what i have seen so far. I have a couple quick questions and hope for a little help and advice.
I just purchased this "fix er upper" and I am planning to remodel my master bedroom. The guy who half assed this place together used OSB when he did the walls in the bedroom. Why? I dont know. He says her removed all the plaster and Lath and just threw up some OSB rather than Dry wall.
My question is what would be the best way to remodel this room. I want to go with dry wall. Should i take off all the OSB and rock it or get 1/4 sheetrock and just go over it? If i do the second option i then run into problems when i get to outlets as thye will not be flush with the new wall.
My last question is on the ceiling. the current ceiling is not in too bad of shape. Its plaster with some kind of popcorn or heavy textured paint. I really dont like the texture so i am wondering what would be the easiest way to fix this. My only thought would be hang some fernon strips and drywall.
Only thing is i dont want to spend a fortune on this room. I am 22 years old and want to get this house in better shape without spending a ton of money. I do plan on all new window and door trim and baseboards. Thanks for reading and all advice and tips is very appreciated. -Conde54
Conde54 is offline   Reply With Quote
Old 01-16-2011, 07:46 AM   #2
Super Moderator
I would pull off the OSB--then you will be able to update any electrical--change the box cover rings to 1/2 inch for the drywall
and insulate.
Any body that hung OSB in a bedroom probably was clueless to common building practices and checking anything he touched would be wise.--Mike--
Old 01-16-2011, 09:44 AM   #3
Residential Renovations
Tattoo's Avatar
Other than what Mike already mentioned you will also run into door jam and windows not being flush with your finished wall if you add drywall over the osb..... You should remove osb and replace it with drywall.....
Tattoo is offline   Reply With Quote
Old 01-16-2011, 10:39 AM   #4
Thanks guys!
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 11:05 AM
Storm Door Selection/Brand Advice Wanted kc27 General Discussion 3 10-25-2009 09:17 AM
New System Advice jkspup22 HVAC 1 03-25-2008 09:48 AM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 12:51 PM
Deck - 45º spindles - advice wanted (pics inside) Kevin K Building & Construction 21 06-06-2007 11:28 AM
