Remodeling - Remodeling - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 09:24 AM   #1
remodeling
remodeling a 1975 mobile home any advice?
mbliffert is offline   Reply With Quote
Old 07-27-2010, 08:09 PM   #2
Rewards Points: 282
Any or all of the interior walls can be moved or removed, only exterior walls are structural. One exception might be in the case of excessive rot in outer walls. Lumber is generall less thick in walls and floor and roof. expect to replace subfloor as there are areas that tend to trap water and rot. How is the roof? Any low spots? This can be caused by truss pieces topling over. Plumbing lines are generall of smaller diameter than house counter parts. Mobile homes are full of short cuts in general that make them less expensive than a equivalent house. They are not all necessarily created equal, depending on the make, some are better built than others. The heat systems are generally simpler. Door frames tend to be shorter than the standard height. A bath tub is 4'6" rather than a full 5'. In other words you can't necessarily buy a replacement part or fixture or appliance in a home improvment center and expect it to fit. Some house replacements can be used with special adaptations.
Are you looking for something more specific?
Jim F is offline   Reply With Quote
Old 07-30-2010, 12:33 PM   #3
Rewards Points: 5,336
You might want to find forums dedicated to these, as they will have their own unique set of needs.
Ron
Remodeling during winter - safety? Snav General DIY Discussions 8 02-17-2010 06:58 PM
Remodeling Kitchen/Bath - Where to Begin??? msmiller36 Roofing/Siding 1 01-06-2010 03:44 PM
Crow Contracting Company- Central Indiana, North Indianapolis- Remodeling Contractor CCCo. Introductions 4 10-11-2009 03:10 PM
Remodeling kitchen - to what extent do I need to bring up to code? TomServo Electrical 2 10-10-2009 09:43 PM
Remodeling Kitchen/dining & Blueprints. Jkslate Remodeling 2 01-22-2008 03:05 PM
