Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-12-2012, 05:08 PM   #1
remodel
how do you know what you can and cant remove as far as walls go in a manufactured home?
howard41 is offline   Reply With Quote
Old 09-12-2012, 08:12 PM   #2
Super Moderator
remodel
That's a tough question for any one to answer without seeing the structure---
Is the manufacturer still in business? If so a call to their engineering department may be worth the call.
Old 09-13-2012, 01:03 AM   #3
remodel
If it's a single wide there are no supporting walls.
If fact your going to be shocked when you see just how little that walls made of.
I've seen then made with nothing but 1 X 4's and staples. Some had 2 X 2 studs.
If your thinking about moving or removing a wall make sure you know what your going to do about fixing the funky ceiling material, and your going to be stuck with some floor repairs.
Old 09-17-2012, 10:04 AM   #4
remodel
True. Singlewides are usually made of 2x4 perimeter walls and 1x3/1x4 interior walls and nothing more than staples holding your interior walls together. a few months ago i just finished gutting a 14x48 singlewide, and except for the perimeter walls, there wasnt a nail to be found. Interior walls of a mobile home are flimsy because the exterior walls support all of the weight. Doublewides im not sure, i would call the manufacturer, or pull the sheetrock down and see if it is a loadbearing wall
firsttimeremode is offline   Reply With Quote
The Following User Says Thank You to firsttimeremode For This Useful Post:
mae-ling (09-17-2012)
Old 09-17-2012, 11:35 PM   #5
remodel
Really depends on the type and p[possibly year of the manufactured home. New ones around here are much better built, more like a house.
mae-ling is offline   Reply With Quote
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 06:54 AM
Insulation maitenance after remodel k2000lbs Insulation 10 02-19-2012 11:04 AM
General Steps to a bathroom remodel jdt141 Building & Construction 1 01-10-2011 08:32 PM
Double Bathroom Remodel coreyandnicole Kitchen & Bath Remodeling 1 03-19-2010 10:59 PM
remodel box for wall fixture DIYGST Electrical 4 01-02-2010 04:21 PM
