Reglazing fiberglass tubs
Hey all.
I did a little searching about re-glazing tubs and read some of the pros and cons about having a tub reglazed. Well, I have a one piece fiberglass shower / tub stall that needs refinishing (teal...ugh!). Given the the geometry of my house, it will be impossible to replace or install a cover, so re-glazing is my only option, if it is even an option for what I have.... so here's my questions.
1) I'm sure it is fine, but I haven't found any definite answers... is it possible to re-glaze fiberglass tubs?
2) Before having a pro come in to do the job, I was wondering if that in order to reduce the likelihood of the re-glaze failing, should I load the tub with water and inject a heavy duty adhesive foam under the tub to limit the amount of flex that the tub structure will have with use?
3) I'm having trouble finding companies that re-glaze in the state of Maine. Closest I have found was New Hampshire. Anyone here know of any reputable companies that offer this service?
Thanks.
