Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 11-29-2012, 08:09 PM   #1
Refinishing Cabinets with laminate sides
I have kitchen cabinets that are kinda old and ugly. I was going to get new doors to update the look and sand the existing frames...BUT while the front of the cabinet frames is wood, the sides of it seem to be laminate or something!!
What are my options? Can I cut a ultra thin piece of ply on the 3 exposed laminate sides and stain that? Should I just paint it all instead? Any other ideas?
Thanks!
flamingoezz is offline   Reply With Quote
Old 11-30-2012, 06:16 PM   #2
You can get 1/4 plywood sheet and cut to fit the sides but you will have to do something to hide the ply. I use the 1/4 on the sides and just veneer the front so it hides the side of the plywood and everything can stained the same. Or get wide veneer to cover the sides.
iGeek is offline   Reply With Quote
Old 11-30-2012, 08:39 PM   #3
STAFF
BigJim's Avatar
You can get 1/8 inch plywood also. Does your face frame over hang the sides a little?
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
White Laminate Cabinets Problem Shamrock Painting 5 05-01-2011 08:59 AM
Laminate? Install cabinets before? MikeVila Flooring 15 11-04-2010 10:58 PM
painting laminate cabinets nolagd Painting 1 09-25-2008 06:21 PM
cabinets ontop of laminate flooring? johnny331 Flooring 7 11-15-2007 10:17 PM
