-   -   Refinishing Cabinets with laminate sides (http://www.diychatroom.com/f15/refinishing-cabinets-laminate-sides-165117/)
flamingoezz 11-29-2012 07:09 PM
I have kitchen cabinets that are kinda old and ugly. I was going to get new doors to update the look and sand the existing frames...BUT while the front of the cabinet frames is wood, the sides of it seem to be laminate or something!!
What are my options? Can I cut a ultra thin piece of ply on the 3 exposed laminate sides and stain that? Should I just paint it all instead? Any other ideas?
Thanks!
iGeek 11-30-2012 05:16 PM
You can get 1/4 plywood sheet and cut to fit the sides but you will have to do something to hide the ply. I use the 1/4 on the sides and just veneer the front so it hides the side of the plywood and everything can stained the same. Or get wide veneer to cover the sides.
BigJim 11-30-2012 07:39 PM
You can get 1/8 inch plywood also. Does your face frame over hang the sides a little?
Fixithickey 02-16-2014 07:39 PM
You can purchase sheets of wood veneer (you can get species specific too) and cut them to desired size as well as stain them. The ideas the other guys are sharing though may be cheaper but the stainable veneer may look more professional
joecaption 02-16-2014 07:44 PM
Need a picture of what you have now.
A veneer is the best way to go.
KinNorth 02-22-2014 07:55 PM
Sometimes just a painted frame looks ok.
atun willis 03-07-2014 07:03 PM
yes..i agree...and it's less job to do
