Refinish Air Register? - Remodeling - DIY Chatroom Home Improvement Forum
Old 08-09-2008, 01:58 AM   #1
Refinish air register?
Greetings all,
I just repainted a room and one thing that I've also been meaning to fix up are the air registers. I wanted to replace them, but the screw locations on the Lowe's and Menard's 10"x6" registers are off by about half an inch.
All the ducts were put in when the house was built in the late 50s, so it's probably an older mounting standard?
Anyhow, perhaps the only way would be to just strip off the many layers of paint (probably a few with lead) on it, and respray it with one good coat of white.
I'm using a product called Motsenbocker's Lift Off Paint & Varnish Remover. That should get it down to the bare metal.
I think it's made of iron or steel? I should prime it as usual, and spray?
Also, I should be able to use your standard Krylon spray paint? I shouldn't need to worry about hot air melting the paint when winter rolls around?
I don't think the hot air gets hot enough to warrant the use of Krylon Hight Heat and Radiator spray paint?
Joony is offline   Reply With Quote
Old 08-09-2008, 08:22 AM   #2
Eibwen
I've repainted all of mine with just a regular can of spray paint. Heat in the winter shouldnt be a problem.
Unless they are really nasty, try just sanding one smooth and spray it versus stripping it all the way. If you do strip it all the way, then it should be primed before its top coated.
While you have the register down, make sure to check the taping around the ductwork to make sure its not leaking in hot/cold air.
Sammy is offline   Reply With Quote
Old 08-09-2008, 09:00 AM   #3
Registered User
Termite's Avatar
I've sprayed mine with muriatic acid. The old paint leaps right off leaving clean, bare metal. Use spray primer on the bare metal, then finish color. Works great.
Heat isn't a concern. The air coming out of the vents isn't really all that hot. High heat paints are for engine blocks, BBQ grills, etc. HVAC systems don't put out super-hot air. You can use any spray paint you like.
Old 08-09-2008, 08:56 PM   #4
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
I've found that appliance spray paint works good. Go gloss for easy clean up.
Sir MixAlot is offline   Reply With Quote
Tags
register heat refinish
Install Register Boot in finished ceiling? rockyfan206 HVAC 1 03-06-2008 05:26 AM
Molding over heat register patrickosu Remodeling 4 02-15-2008 11:07 PM
Replacing flush mount wooden floor vent (register) csteinke Flooring 3 09-30-2007 08:01 PM
add an additional register to a supply line b2v HVAC 1 06-20-2006 06:55 PM
