12-31-2010, 02:11 PM
#1
redoing the railing in a split-foyer
12-31-2010, 06:31 PM
#2
The short wall with the wood top should be easy, depending on how much you leave for the step finish trim. Not sure about the high wall, I suspect it is load bearing. You need some on site expert advice for that.
12-31-2010, 09:57 PM
#3
well on the short wall I'd like to do something like this
on the big wall, I only want to remove the upper part down to finished floor.
01-01-2011, 12:22 AM
#4
I agree with Bill you probably will have to put in a beam for support if you try and remove the tall wall because it looks to be load-bearing to me as well. You need to definitely have a structural professional look at it before removing any part of it.
12-06-2011, 10:52 AM
#5
Well it's been a year and I finally got around to doing this project! I thought I would update you all with some pictures. Here's is a link to my picasa album.
https://picasaweb.google.com/AndyHaw...eat=directlink
I am very pleased with the way it turned out. Let me know what you all think!
Thanks!
Andy
01-31-2012, 04:04 PM
#6
Andy,
That looks great! I wanna do the same style railing. I don't have the half-wall style, so I'll just have to remove the old railing and install the new railing and balusters. Did the top of your balusters have a round or square end? I ask becuase the ones in Home Depot are square on top and I can't figure out why. It's sort of hard to drill a square hole, if you know what I mean. I'm guessing you could just drill a round hole that's enough to accept the square end and then use the caps that you have used. Is that what you did?
Also, it looks like you just screwed the bottom plate to the floor, plugged the hole, sanded the board and stained. Is that correct?
Thanks,
Kevin
01-31-2012, 05:28 PM
#7
Looks Good!
02-01-2012, 12:43 AM
#8
Originally Posted by Ler0y Jenkins
Andy,
Thanks,
Kevin
I got the balusters at lowes. They are round at the top and square on the bottom. I used forstner bits and drilled a 1/2" hole for the top and 5/8" for the bottom. For the bottom plate are you talking about the oak 1x6? If so, I used a 15 gauge nail gun and nailed it to a 2x4 cap I screwed down. I then filled the nail holes and sanded and stained.
02-01-2012, 02:27 PM
#9
Andy,
Yes, the 1x6 is what I was referring to. Thanks for the info. Again, it looks fantastic. 1000% better than before.
Kevin
02-01-2012, 04:06 PM
#10
Andy,
One more question... how did you go about drilling the 5/8" holes in the bottom plate for the stair section that's slanted? I imagine it might be kind of hard to drill on an angle with the forstner bits. Any tips?
Kevin
02-01-2012, 05:23 PM
#11
STAFF
LerOy J if you look at this picture you will see the spindles are square at the top and bottom. This is a hampton style rail system, the bottom of the rail is plowed out and has a shoe on the bottom that is plowed out. Plowed means there is a recess in the bottom of the rail and shoe.
The hampton rail is the easiest of rails to install for me.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
02-02-2012, 11:15 AM
#12
Jim,
Thanks for the response... I was actually thinking of doing that style of railling before I came across some pictures of the wood/wrought-iron style. I just really like the look of the wood railing with the wronght-iron spindles.
Kevin
02-02-2012, 11:52 AM
#13
STAFF
Jim,
Kevin
I agree with you, the rail with the wrought-iron spindles does look far better and up to date. That style rail is a little tougher but it is for sure doable with some instructions. You will want to be sure your posts are set firm and the rails connected by stair bolts as the spindles don't contribute much support to the system at all.
Jim
02-03-2012, 09:16 AM
#14
Actually I took some of your photos to show our contractor as we have a split level that we are remodeling for resale / rental. We had already taken down the upper wall to open that space but the lower half wall will be coming down today in order to accomodate the look as well.
thanks for sharing.
02-03-2012, 09:31 AM
#15
Disabled wood vet
Like this:
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
