Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 02-17-2010, 11:16 AM   #1
reclaiming garage space
I have a small alcove in the garage where the steps to the house door go. I am intending to frame this in and make it part of the house to expand the mudroom. Since the foundation wall around the perimeter of the garage follows the stair alcove when I frame joists across the space I will have garage floor under it with a 4 to 6 inch space. What do i do with this space - do I block it off with pressure treated lumber that acts like the foundation along the front edge, or try to put a "bottom" inside the joists to seal it? Do I need a vapor barrier? I also want to stuff in insulation but I don't want things crawling under and nesting in it. Thoughts?
Scott2 is offline   Reply With Quote
Old 02-17-2010, 02:47 PM   #2
Can you post a few photos? I'm having a hard time visualizing the situation.
Ron
Old 02-18-2010, 08:17 AM   #3
Sorry it sounds confusing. I attached a house plan and maybe that will help. The area I was trying to describe is where the stairs are in the garage. I only have two steps so I'm moving them outward and then framing the space into the house mudroom (Family Foyer on the plans) if that makes sense?
Old 02-18-2010, 08:26 AM   #4
panel the sides, yes insolate , if coming back with new steps have risers people around here have been snake bit going into garage from house at steps
The older I get the better I was
Help me utilize the space over my Garage Mr Chips Building & Construction 9 06-15-2009 03:48 PM
Attic space above garage chris0914 Building & Construction 5 01-19-2009 08:04 PM
Are You Wasting Space In Your Garage? BJLower Carpentry 2 10-07-2008 08:54 PM
storage space in the Garage over cars jchildress Remodeling 2 07-06-2008 12:20 AM
How to attach this garage and convert it into a living space? BleachCola Building & Construction 16 02-02-2008 04:40 PM
