Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Remodeling
Old 09-09-2007, 11:15 PM   #1
Recessed lighting confusion
Hello everyone,
I am a bit confused on the terminology surrounding recessed lights. I fully understand the IC and non-IC designations. My confusion comes when you begin to talk about the housing and trims. To me, the trim should mean nothing more than just a cosmetic trim ring and the housing should comtain everything else..is that correct? I did a search for 'recessed' on here and didnt come up with an answer to my question. I did however see that I should look at the Juno brand. So I am linking to a product at Lowes and will try to go by monday after work to check it out, but is this all i need (and some beauty trim ring)??
http://www.lowes.com/lowes/lkn?actio...C22&lpage=none
Juno Lighting
1 Light IC New Construction Housing Recessed Lighting
FYI: I am doing a new construction.
sleepy23 is offline   Reply With Quote
Old 09-10-2007, 12:36 PM   #2
Yes, it sounds like you pretty much have it figured out. The trim will make more sense once you get to the store, as they usually have a display that shows all the different trim styles. The housing is just what you think it is.
billinak is offline   Reply With Quote
Old 09-10-2007, 01:56 PM   #3
cool. thanks.
Old 09-10-2007, 04:17 PM   #4
one more. what about Utilitech brand housings? I can get a contractor pack for pretty cheap or should I just go with the original link?
Old 09-11-2007, 12:31 PM   #5
Pretty much any of those brands are the same, I got the Halo contractor pack at HD, the important part is the IC/non IC and the new construction/remodel. I also recommend using one of those rotary cut out saws to cut the holes. You might only use it once, but the holes are perfect.
Old 09-12-2007, 11:30 PM   #6
remodeling pro
[quote=sleepy23;62150]Hello everyone,
That depends on the manufacturer and model of the can. Lightolier(longtime), and Halo (recently) manufacture cans with baffle/trim inserts where the lampholder clips into the top of the baffle/trim piece and holds the bulb at the exact proper height and always centered, as oppossed to the cans that hold the bulb socket out on that trashy little piece of sheet metal that results in the bulbs almost always being off center in the trim, which in this case is usually a flimsy piece of plastic held in place by a couple of springs. I think these provide a far superior fixture and are worth taking a look at.
troubleseeker is offline   Reply With Quote
Recessed Lighting In Basement Rifeman Remodeling 12 09-06-2007 02:26 PM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
recessed lighting in basement DIY4EVER Electrical 6 06-29-2007 03:52 PM
Recessed lighting in drop ceiling DIY4EVER Electrical 9 06-04-2007 05:46 AM
recessed lighting automation cesar333 Electrical 3 12-28-2005 09:54 AM
